Is {x+y(cuberoot of 3) + z(cuberoot of 9) | x,y,z is in Q} a Subfield?
  • Context: Graduate
  • Thread starter Thread starter lilcoley23@ho
The discussion revolves around the question of whether the set {x+y(cuberoot of 3) + z(cuberoot of 9) | x,y,z is in Q} can be considered a subfield. Participants explore the necessary conditions for a subset to qualify as a subfield, including closure under various operations and the existence of multiplicative inverses.
  • One participant expresses confusion about the requirements to prove that the set is a subfield, specifically questioning the need to show closure under division and commutativity.
  • Another participant emphasizes the importance of demonstrating all field axioms, including associativity, commutativity, distributivity, identity, and inverses for both addition and multiplication.
  • There is a discussion about the specific conditions needed to show that a subset is a subring and how those relate to proving it is a subfield.
  • A participant mentions the need to show that the set does not contain zero and that it is closed under subtraction and multiplication.
  • One participant proposes that showing the existence of multiplicative inverses for non-zero elements is crucial for proving the set is a subfield.
  • Another participant provides a proof involving the mapping from Q[X] to Z[cuberoot of 3] and discusses the irreducibility of the polynomial X^3-3 as a means to establish that Z[cuberoot of 3] is a field.
  • Concerns are raised about whether focusing solely on Z[cuberoot of 3] neglects the contributions of the x and y components in the original equation.
Participants generally agree on the need to demonstrate closure under addition, multiplication, and the existence of inverses, but there is no consensus on the sufficiency of these conditions or the relevance of specific components of the set in question. The discussion remains unresolved regarding the complete criteria for establishing the set as a subfield.
Some participants reference specific mathematical properties and axioms without fully resolving the implications of these properties in the context of the set being discussed. There is also a lack of clarity on how to handle the denominators and the specific forms of elements within the set.
lilcoley23@ho
I'm taking an independent study class over Groups. Rings, and Fields. It's been really confusing. On one page I understand everything completely and the next page I'm completely lost. I'm looking at a problem where I has to show that {x+y(cuberoot of 3) + z(cuberoot of 9) | x,y,z is in Q} is a subring. Now I think I got that...but then I want to prove that it's a subfield. Since I prove that it's a non-empty subset and closed under addition and multiplication by showing that it's a subring, then all I further have to show is that it's a field. (Because to show something is a subfield you just have to show that it's a subset and a field.)
Then to show that the ring is a field you just have to prove it's closed under addition, subtraction, multiplication, division, and it must be cummutative...Right? So in this case I just have to prove that it's closed under division and cummutative??
I know that my denominator will look like: x^3 + 3y^3 +9z^3 - 9xyz but I really need help!
Thanks!
To show something is a field you need to show field axioms. Properties like division for example don't always make sense when talking about abstract fields.
Have you looked at showing these properties hold:
http://mathworld.wolfram.com/FieldAxioms.html
So if I can show that all 5 of those properties hold for x+y(cuberoot of 3) + z(cuberoot of 9) than I can prove that x+y(cuberoot of 3) + z(cuberoot of 9) | x,y,z is in Q} is a subfield?
If that's the case can you maybe help me with the first one? Like associativity?
I would really appreciate it. I think I'm making it harder than it has to be...and where does the denominator looking like: x^3 + 3y^3 +9z^3 - 9xyz come into play?
Well you want associativity for both operations. You said you have addition and multiplication so for addition, you want to show
[tex](a + b \sqrt[3]{3} + c \sqrt[3]{9} + d + e \sqrt[3]{3} + f \sqrt[3]{9}) + g + h \sqrt[3]{3} + i \sqrt[3]{9} = a + b \sqrt[3]{3} + c \sqrt[3]{9} + (d + e \sqrt[3]{3} + f \sqrt[3]{9} + g + h \sqrt[3]{3} + i \sqrt[3]{9})[/tex]
Can you show that just because rationals are associative under addition?
I'm not sure? I know that it's proven that addition and multiplication of rational numbers are associative and cummutative, but I don't know if that's all you have to show to prove it?
Also...are you telling me that if I prove associativity, commutativity, distributity, identity, and inverses for both addition and multiplication for this equation that I have proved that it's a subfield? I thought I had to prove so much more!
I just don't see that...to prove something is a subring it says you have to show that
1. S doesn't equal 0
2. S is closed under subtraction
3. S is closed under multiplication
More precisely:
2. For all a,b in S we have a-b in S and a,b in S
Then for subfield you must show that:
1. S - {0} doesn't equal 0
4. x is in S-{0} ==> x^(-1) is in S
"To show something is a field you need to show field axioms" is not the only way, in fact, it is usually much easier to show that something is a subfield of something.
lilcoley23@ho, your last post contains all you need. Now that you proved that A is a subring of B. You need to do two more things, show that 1!=0, and that the set A\{0} has multiplicative inverses!
p.s What text are you using?
There's a type in your last post though, in case you aren't aware of (but you probably are)
More precisely:
It is For all a,b in S we have a-b in S and a.b in S
So to show S was a subring of (R , + , .) I used the more precise version I talked about in my last post:
So, = 0 is in S and so, S is a non empty subset of R
Therefore, S is a subring of R.
Now condition 2:
Let say, x1+y1(cuberoot 3) + z1(cuberoot 9), x2+y2(cuberoot 3) + z2(cuberoot 9) are in S
Then, x1, x2, y1, y2, z1, z2 are in Q
So, (x1-x2), (y1-y2), (z1-z2) are in Q and (x1-x2)+(y1-y2)(cuberoot 3) + (z1-z2)(cuberoot 9) are in S
Therefore, (x1+y1(cuberoot 3) + z1(cuberoot 9)) - (x2+y2(cuberoot 3) + z2(cuberoot 9)) are in S
AND
So: (x1+y1(cuberoot 3) + z1(cuberoot 9) * (x2+y2(cuberoot 3) + z2(cuberoot 9))
==> {x1x2 + 3y1z2 + 3y2z1} + {x1y2 + 3z1z2 + 3x2y1}(cuberoot 3) + {y1y2 + x1z2 + x2z1} (cuberoot 9)
Which shomws that if x1+y1(cuberoot 3) + z1(cuberoot 9), x2+y2(cuberoot 3) + z2(cuberoot 9) are in S
Therefore: (x1+y1(cuberoot 3) + z1(cuberoot 9)) * (x2+y2(cuberoot 3) + z2(cuberoot 9)) are in S
So is that right? And if it is can you please tell me what else I have to show to show it's a subfield...
I've never seen anything with "show that 1!=0, and that the set A\{0} has multiplicative inverses"
And about my book...I'm not sure...I use mostly on-line. Really none of the problems I'm trying to solve are like any in the book!
Lilcoley23
Regarding "1!=0" and " the set A\{0} has multiplicative inverses", they'are just anyway of rephrasing the subfield test, so nevermind about them.
To show it's a subfield, assume that an element exists and it doesn't equal to zero, now show that its inverse also exists.
I think I haven't been quite explicit enough, sorry,
The last question about the existence of a multiplicative inverse is: is it possible to write [tex]\frac{1}{ x+y\sqrt[3]{3} + z\sqrt[3]{9} }[/tex] in the form [tex]a+b\sqrt[3]{3} + c\sqrt[3]{9}[/tex]. What values of [tex]a[/tex], [tex]b[/tex], and [tex]c[/tex] (for each x, y, and z) do we need then.
Do they belong to [tex]\mathbf{Q}[/tex].
$$f$$
well, so you need to show Z[cuberoot of 3] is a field.
Proof 1.
Think of the map Q[X] to Z[cuberoot of 3] that maps X to "cuberoot of 3". This is obviously a surjective ring-homomorphism. The kernel is the ideal generated by an irreducible polynomial X^3-3. Thus we have an isomorphism Q[X]/(X^3-3) onto Z[cuberoot of 3]. Since (X^3-3) is a maximal ideal, Q[X]/(X^3-3) is a field, so Z[cuberoot of 3] is also a field. ////
I'm sorry,
but I dont' understand why you're just looking at Z(cuberoot 3) instead of the whole equation? Is the x+y(cuberoot of 3) part of the equation irrelevant?
Please help me understand!
I denoted a ring generated by "cuberoot of 3" over Z by Z[cuberoot of 3].
Let us denote the cube root of 3 by r for the sake of notation.
Then the set in question is the same as Z[a] because a^3=3.
By the way, in general, if K is a subfield of F and a is an element of F algebraic over K, F[a]=F(a). Here, F(a) denotes the smallest subfield of F that contains K and a.
HERE IS ANOTHER PROOF (basically the same as the one I gave yesterday).
Cuberoot of 3 is a root of an irredicuble polynomial X^3-3. Any nonzero element p of the ring in question is of a form f(cuberoot of 3), where f (=:f(X)) is a polynomial over Z. Since p is not zero, X^3-3 doesn't divide f(X). (If it does, f(p)=0.) As X^3-3 is irredicible, X^3-3 and f(X) are relatively prime. Hence by the Chinese remainder theorem there are nonzero polynomials h(X) and k(X). such that h(X)(X^3-3)+k(X)f(X)=1. Substitute "cuberoot of 3" for X. Then we obtain k(cuberoot of 3)p=1. (f(cuberoot of3)=p by def.) So p has an inverse. ////
  • · Replies 17 ·
