Method of undetermined coefficients
The method of undetermined coefficients is applied to solve the differential equation 2y'' + y' = cos(2x) + 4x + 1. The first particular solution, yp1, is determined for the cos(2x) term. For the polynomial term 4x + 1, the appropriate guess for the particular integral (PI) is of the form Ax^2 + Bx + C, due to the presence of a root at 0 in the auxiliary equation. This approach ensures that the degree of the polynomial in the guess is one higher than that of the non-homogeneous term.
  • Understanding of differential equations and their solutions
  • Familiarity with the method of undetermined coefficients
  • Knowledge of auxiliary equations and their roots
  • Basic polynomial algebra
  • Study the method of undetermined coefficients in detail
  • Learn how to derive particular integrals for different types of non-homogeneous terms
  • Explore the implications of roots in auxiliary equations on particular solutions
  • Practice solving various differential equations using the method of undetermined coefficients
Students and professionals in mathematics, particularly those focusing on differential equations, as well as educators teaching the method of undetermined coefficients.
s7b
Hi,
When using the method of undetermined coefficients to solve
I did it term by term. I figured out the first yp1 for the cos(2x). I'm just not sure what to "guess" as to the form of the yp2 for 4x+1
Does anyone know what to use as the guess?
when you solved the auxilary equation if one root was 0, then for a polynomial, the particular integral would be a degree higher. For example if you solved and 0 was a root of the aux. eq'n. and the right side was ax+b, then the PI would be Ax^2+Bx+C
It is easy to know what to guess.
[D^2+2^2]cos(2x)=0
[D^2](4x+1)=0
Guess the solution to lcm{[2D^2+D],[D^2],[D^2+2^2]}=[D^2][2D+1][D^2+2^2]
