Need help with a diffractiongrating problem.
  • Thread starter Thread starter seanmcgowan
The problem involves calculating the angle of diffraction for light passing through a diffraction grating, specifically focusing on the second order diffraction with a given wavelength and grating density.
  • Mathematical reasoning, Assumption checking
  • The original poster attempts to rearrange the diffraction equation to solve for the angle but expresses confusion over the results. Some participants question the calculations and the values used for the grating spacing.
Participants are actively reworking calculations and discussing potential errors in the values used for the grating spacing. There is a recognition of differing results, and some guidance is offered to clarify the calculations, but no consensus has been reached on the correct approach yet.
There are indications of confusion regarding the correct value of the grating spacing, with different interpretations of the units and calculations leading to varied results. The original poster is preparing for an upcoming test, which adds urgency to the discussion.
seanmcgowan
Light with a wavelength of 400nm passes through a 1.00x10^4 lines/cm diffraction grating. What is the second order angle of diffraction?
a) 21.3 c)56.5
b) 53.1 d) 72.1
d*sin(theta)=m* wavelength
I rearranged the equation to: Theta= sin^-1({wavelength*order}/ d)
Theta= sin^-1 (4*10^-7*2/{1/1*10^2)= sin^-1(8*10^-9)= 4.58366
Obviously, this isn't the answer. Could someone show me how to figure these problems out? I have a test coming up and i am completely stumped on all of these types of questions.
Here d = 0.01/1x10^4 m or 10^-6 m.
Ok i reworked the problem, and got a different answer, but it is still no where near any of the multiple choice answers! what am I doing wrong?
Can you show your second calculation, with the new value of d? Otherwise we can't see what's wrong.
EDIT:
4*10^-7*2/(1/1*10^2) = 8*10^-9
There is an error here, besides the incorrect value of d. Do you see it?
Holly cow! I just re-reworked the problem for about the hundredth time and got the answer of 53.1, which is actually one of my choices! and I should imagine that the (8*10^-9) is wrong. The answer should be 8*10^-1. Right? or am I STILL messing up?
Yes, it is 0.8 using the correct value of d=10-6m.
Or, if d=(1/102)m or 10-2m as you had earlier, you should have gotten 8x10-5 for the expression.
