I am sure this is easy but i am stuck
  • Thread starter Thread starter Vane9488
    Stuck
The problem involves calculating the resultant displacement of a grasshopper's jumps, represented by multiple displacement vectors with specified magnitudes and directions. The subject area pertains to vector addition and trigonometry.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the proper accounting of vector components, questioning the signs of the magnitudes based on directional conventions. Various methods for breaking down the vectors into components are presented, with some participants expressing confusion over the calculations and the final direction.
Multiple interpretations of the vector addition process are being explored, with some participants offering guidance on setting up equations and checking signs. There is no explicit consensus on the correct resultant displacement, as participants continue to verify their calculations and assumptions.
Participants note the importance of expressing the direction of the resultant displacement with respect to due west, which adds complexity to the problem. There are indications of confusion regarding the application of trigonometric functions and the proper handling of vector components.
Vane9488
The question: A grasshopper makes four jumps. The displacement vectors are (1) 27.0 cm due west (2) 23.0 cm, 35.0[tex]^{o}[/tex] due south of west (3) 28.0 cm, 55.0[tex]^{o}[/tex] south of east and (4) 35.0 cm, 63.0 [tex]^{o}[/tex] north of east. Find the magnitude and direction of the resultant displacement. Express the direction with respect to due west.
Vector magnitude direction x component y component
(1) 27.0 cm 0 [tex]^{o}[/tex] 27 cos 0[tex]^{o}[/tex] 27 sin 0[tex]^{o}[/tex]
(2) 23.0 cm 35.0 [tex]^{o}[/tex] 23 cos 35[tex]^{o}[/tex] 23 sin 35[tex]^{o}[/tex]
(3) 28.0 cm 55.0 [tex]^{o}[/tex] 28 cos 55[tex]^{o}[/tex] 28 sin 55[tex]^{o}[/tex]
(4) 35.0 cm 63.0 [tex]^{o}[/tex] 35 cos 63[tex]^{o}[/tex] 35 sin 63[tex]^{o}[/tex]
r= resultant variable
I add all of the x components and I get 62 cm.
I add all of the y components and I get 49.5 cm.
r=[tex]\sqrt{x^{2}+ y^{2}}[/tex]
r=111.5 cm
the direction i get 38.6[tex]^{o}[/tex].
Thats not the right answer! Please help!
Welcome to PF.
I'm not sure you have properly accounted for the signs of your magnitudes. For instance with positive x East then your west vector would be negative.
LowlyPion said:
Welcome to PF.
I am still not getting the right answer with this! I am really confused now!
I haven't done vector addition in a while but here it goes!
I use Dx to label the vectors corresponding to the jumps in sequence. I set up my unit so that west is -x and south is -y which is standard I suppose.
D1 = -27cm (negative because it's going west)
D2x = -13.19cm (you get this by sin(35)*23cm, keep in mind that this is a negative because it's moving westward in the x direction.)
D2y = -18.84cm (Same process of above except cos(35)*23cm)
Now that you got the hang of things I'm going to run down to my solution.
D3x = 16.06cm
D3y = -22.93cm
D4x = 15.89cm
D4y = 31.18cm
Sum of X's = 45.76cm
Sum of Y's = -10.59cm
Make a triangle using those two components and your hypotenuse is the composite vector. 46.97cm 13.03o S of E
Is that correct?
D3x = 16.06cm
D3y = -22.93cm
D4x = 15.89cm
D4y = 31.18cm
Is that correct?
I don't think so because it asks me to express the direction with respect to due west.
Vane9488 said:
No because it asks me to express the direction with respect to due west.
Well that is actually really simple. 13.03o S of E can be converted to W by simple subtraction. 180o - 13.03o = 166.97o
That is to say the new direction is 166.97o S of W.
I hope this helps.
I hope this helps.
Thank You very much but I am still confused
Solving vectors for me is basically 3 steps.
1. Setup two equations. One that adds together all the x components and one that adds together all the y components. For you problem my equations looked like this:
Xtotal = D1 + D2x + D3x + D4x
Ytotal = D2y + D3y + D4y
I use the subscripts to number each vector, and the x/y's to label the x or y component. Notice that since D1 is completely due west it is only present in the x equation because it has no y component.
2. Solve for the components. Use trigonometry to draw out each vector and break it into components. Be mindful of the direction of the vector. If it's moving downwards it's y component will have a negative. If it's moving to the right it's x component will have a negative as well.
3. Plug and chug. Plug all your x and y values for D1...D4 into your two equations from step one. This gives you the total displacement in the x and y directions. Using these values (and watching the signs) you can draw a traingle which becomes your composite vector. All you need now are the Pythagorean theorem and an inverse sine or cosine to find the direction.
Hope this clears up my process.
D3x = 16.06cm
D3y = -22.93cm
D4x = 15.89cm
D4y = 31.18cm
Is that correct?
Sorry. I think you got your x,y and sin,cos reversed.
Otherwise it looks ok ... except for the result.
You're right I did flip those.
For my new sums I get 23.79 for x and -4.94 for y.
24.29cm @ 11.64o S of E or 168.36o S of W
I think that's better.
I didn't run the numbers.
The OP is encouraged to verify to be certain of the proper magnitude.
mmacholl: That still doesn't look quite right yet. I currently got R = 14.744 cm at 19.589 deg S of W.
  • · Replies 25 ·
