Find out the number of batteries needed to power 5 devices of 12V for 18 hours
The discussion revolves around calculating the number of batteries required to power five devices, each rated at 12V, for a duration of 18 hours. The battery in question also has a voltage of 12V and a power rating of 9600 watts.
  • Exploratory, Assumption checking
  • Participants are attempting to clarify the load requirements of the devices to determine the necessary current (amps) and subsequently the amp-hours needed for the batteries. There are questions about the power consumption of the devices and how it relates to the overall calculation.
The discussion is ongoing, with participants seeking to understand the implications of load and power consumption on the battery calculation. Some guidance has been offered regarding the importance of knowing the load to calculate the required amp-hours, but there is no explicit consensus yet.
Participants are questioning the assumptions regarding the power consumption of the devices, indicating that knowing just the voltage is insufficient for the calculation.
jesschin
Hi there, I need some help in getting this calculation done. I need to find out the number of batteries needed to power 5 devices of 12V for 18 hours. The voltage of the battery is also 12. Power of battery is 9600 watts.
Please help. Thanks!
Welcome to PF.
The real question is what is the load?
When you know the load - you know the amps.
When you know the amps needed you know the amp-hours needed.
When you know the amp-hours of the batteries ...
LowlyPion said:
Welcome to PF.
sorry, I don really get your point, LowlyPion. Can you explain further in depth? thanks
It's not enough to know what the voltage is of the devices.
You need to know how much power they consume.
  • · Replies 23 ·
