Tank Drainage Work Calculation
  • Thread starter Thread starter daytripper
    Review Tank Work
The discussion centers on calculating the work done to drain a cubic tank with a height of 4 feet, filled to a height of 3 feet, using the integral Work = ∫(density · volume · dist · dh). The user correctly identifies the infinitesimal cross-section and calculates the work as 10483.2. Clarifications reveal that the density of water is 62.4 lbs/ft³, which incorporates gravitational effects, negating the need for an additional gravity term. The final units of work are confirmed to be in foot-pounds (lb·ft) or joules, depending on the unit system used.
  • Understanding of calculus, specifically integral calculus
  • Familiarity with concepts of density and volume in physics
  • Knowledge of units of measurement in both imperial and metric systems
  • Basic principles of work and energy in physics
  • Study the application of integrals in physics, particularly in fluid dynamics
  • Learn about the relationship between density, volume, and force in various unit systems
  • Explore the concept of work in physics, including its calculation in different contexts
  • Investigate the implications of gravitational effects on work calculations in fluid mechanics
Students in calculus and physics courses, educators teaching fluid dynamics, and professionals involved in engineering calculations related to fluid mechanics.
daytripper
Firstly, I'd like to quickly note that this isn't a homework problem, but rather a problem that I'm about to make up. I've done Calc IV already but recently my friend asked me for help on a problem involving the drainage of a tank and I got a little stuck in thought. I'd like to re-educate myself on this.
let's say you have a cubic tank (sides = 4 feet). There's a pipe sticking up 1 foot off the top of the cube. The tank is filled up to the 3 foot mark. For these equations, I will be using the variable h to represent the distance from the top of the pipe to the water's surface.
[tex]Work\; =\; \int_{init}^{final}{density\; \cdot \; volume\; \cdot \; dist\; \cdot \; dh}[/tex]
So an infintesimal cross section of this cubic tank would be 16*dh and it would weight 62.4*16*dh. We're moving it a total distance of h (where h varies from 2 to 5).
So then the equation would be:
[tex]Work\; =\; 62.4\cdot 16\int_{2}^{5}{h\; dh}[/tex]
which evaluates to 62.4 * 16 * 10.5 = 10483.2... and I'm not sure which units this would be in.
To me, it seems that I did this problem correctly. I put it here under "coursework questions", as it's a typical problem you'd run into in a calculus class. The thing that's throwing me off is the fact that gravity isn't taken into consideration. I mean.. it requires more work to move something uphill than downhill, right? So why didn't I have to say something along the lines of " + 9.8*62.4*16*10.5" (that was sloppy deduction, but you get the idea).
Also, if someone could help me out with what units this is in, that'd be helpful as well.
Thanks for all the help. I can never say how happy I am this site exists. =]
-DT
That looks just fine. You questions about it are tied in with not knowing the units. The 62.4 is lbs/ft^3 or force/volume (the force per cubic foot for water on the earth). The 'g' is already built in. The other way do this with a visible 'g' in metric units is writing g*rho as the constant out front, where g=9.8m/s^2 and rho is the mass density of water 1000 kg/m^3. If you multiply those together you get units of (kg*m/s^2)/m^3. Since kg*m/s^2 is a Newton, the metric force unit, then g*rho is again a force/volume. If you continue on, the rest of the calculation has units of volume*length. So, (force/volume)*(volume*length)=force*length. A Newton*meter=joule. The unit of work. Or lb*ft in the daft unit system.
  • · Replies 19 ·
