Why Am I Getting the Wrong Answer on My Molar Entropy Calculation?
  • Thread starter Thread starter CzarValvador
    Chemistry Entropy
The discussion centers on the calculation of molar entropy using the equation ΔS = n Cv ln(T2/T1) for a system at constant pressure. The user initially used Cv for their calculations but was advised to use Cp instead, as the problem specifies constant pressure conditions at 1 atmosphere. The correct approach involves substituting Cv with Cp and ensuring that the volume change is accounted for during the calculation. The user is encouraged to verify their values for T2 and T1, which are 341 K and 298 K respectively, to ensure accuracy in their entropy calculation.
  • Understanding of thermodynamic concepts, specifically molar entropy.
  • Familiarity with the equations for entropy change, particularly ΔS = n Cp ln(T2/T1).
  • Knowledge of the difference between constant volume (Cv) and constant pressure (Cp) heat capacities.
  • Basic skills in manipulating logarithmic functions and temperature conversions.
  • Review the principles of thermodynamics focusing on entropy calculations.
  • Study the differences between Cv and Cp, including when to use each in calculations.
  • Practice problems involving molar entropy at constant pressure using real gas scenarios.
  • Explore the implications of temperature changes on entropy in thermodynamic systems.
Chemistry students, educators, and professionals involved in thermodynamics and physical chemistry who seek to enhance their understanding of entropy calculations and related concepts.
CzarValvador
Working this thing on Web Assign. I feel like I've been doing everything 100% correct, yet I keep getting the wrong answer.
http://img510.imageshack.us/img510/4488/chemkp0.jpg
Basically, I need help on part B and C
What I did for B, I tried to calculate Delta S by using the equation n Cv ln(T2/T1)
I plugged in Cv given in the problem, used 341 for T2, and 298 for T1. n is One, since its for one mole. And I added the value I get to delta S to S that was given in the problem.
What have I been doing wrong.
Maybe you should be plugging in [tex]C_p[/tex]. The question says that the pressure is 1 atmosphere, even at the higher temperature. Therefore you must be operating at constant pressure and your volume must have increased.
I've tried that multiple times. Thanks, though.
