Returning each co-ord between two points of a linear line
The discussion focuses on calculating the coordinates between two points on a linear line for a game scenario. The specific example provided involves player one at coordinates (20,5) and player two at (41,5). The solution involves determining the distance between the x-coordinates and y-coordinates, then incrementally adding to the starting coordinates until reaching the endpoint. This method effectively returns each tile that the line passes through, ensuring real-time updates are feasible.
  • Understanding of coordinate systems in 2D space
  • Basic knowledge of linear equations
  • Familiarity with programming concepts for real-time updates
  • Experience with game development frameworks
  • Implement Bresenham's Line Algorithm for efficient coordinate calculation
  • Explore real-time rendering techniques in game development
  • Learn about tile-based game design principles
  • Investigate optimization strategies for dynamic coordinate updates
Game developers, software engineers, and anyone involved in creating tile-based games or real-time coordinate calculations will benefit from this discussion.
boo1234
Hi,
I need to come up with an equation/solution/way to return each of the co-ordinates between two points in a line.
This is for a game, I want to return the co-ords between two player locations.
Let's say for example player one is at 20,5 and player two is at 41,5
I need to return:
21,5
22,5
23,5
24,5
25,5
and so on up to 41,5
The points are dynamic
Help appreciated.
To clarify I need to return each TILE that the 'line' passes through between two players.
Well you can just take [itex]x_2-x_1[/itex] that gives you the distance [itex]x_2[/itex] to [itex]x_1[/itex] let's call it a, then do the same for y and call it b, now simply add one to each co-ordinate or take one if a or b are negative to [itex]x_1[/itex] and [itex]y_1[/itex] respectively until a=[itex]x_2-x_1[/itex] or until b=[itex]y_2-y_1[/itex]. If a and b respectively are equal to [itex]x_2-x_1[/itex] and [itex]y_2-y_1[/itex] then stop. Should provide you with each co-ordinate between the two points. Being a computer I'm sure it can update that in real time with no problems.
