Can Geodesic Deviation Prove the Gaussian Curvature of a Cylinder is Zero?
  • Context: Graduate
  • Thread starter Thread starter MathematicalPhysicist
The discussion revolves around demonstrating that the Gaussian curvature of a cylinder is zero by analyzing geodesic deviation on its surface. Participants explore the relationship between geodesics and curvature, as well as alternative arguments involving principal radii of curvature.
  • Homework-related
  • One participant presents an equation for geodesic deviation and argues that since geodesics on a cylinder remain parallel, there is no geodesic deviation, leading to the conclusion that Gaussian curvature R is zero.
  • Another participant critiques this reasoning, suggesting that the explanation lacks clarity and does not sufficiently justify the claim about geodesic deviation on a quasi-rectangular surface.
  • A later reply suggests that the cylinder can be "unrolled" into a flat surface, which supports the idea of it being metrically flat, but questions whether this is a valid argument for the problem at hand.
  • Participants discuss the formula for Gaussian curvature involving principal radii of curvature, noting that the minimum radius of a cylindrical surface is finite while the perpendicular radius is infinite, leading to a conclusion of zero curvature.
  • One participant expresses uncertainty about the second argument regarding the point in question for the curvature formula.
  • Another participant indicates a need to find parametric equations for the cylinder to demonstrate that geodesic deviation is null.
Participants do not reach a consensus on the validity of the initial argument regarding geodesic deviation. There are competing views on the clarity and correctness of the reasoning presented, and the discussion remains unresolved regarding the best approach to demonstrate the curvature of the cylinder.
Participants express uncertainty about the definitions and assumptions related to the shape of the cylinder and the implications for geodesic deviation. The discussion includes references to different methods of proving curvature, but lacks a definitive resolution on the most appropriate approach.
The question is:"Show that the Guassian curvature R of the surface of a cylinder is zero by showing that geodesics on that surface suffer no geodesic deviation.
Give an independent argument for the same conclusion by employing the formula
[tex]R=\frac{1}{\rho_1 \rho_2}[/tex] where [tex]\rho_1[/tex] and [tex]\rho_2[/tex] are the principal radii of curvature at the point in question wrt the enveloping euclidean 3-dimensional space."
Now if I write down the deviation geodesic equation I get:
[tex]\frac{d^2\chi}{ds^2}+R\chi=0[/tex] where chi is the distance between geodesics, now because the cylinder has a quasi rectangular shape, the geodesics which start parallel stay parallel thus there is no geodesic deviation, and R=0 cause [tex]\frac{d^2\chi}{ds^2}=0[/tex] and xsi is linear wrt s chi=as+b so R=0.
Is this just plain mambo jambo from my behalf or there's something genuine here?
I am not sure about the second argument, which point is in question here?
Any hints are appreciated.
Anyone?
Any hints?
Can someone move my post to advanced physics HW?, perhaps there my post will get my attention it deserves, or not.
loop quantum gravity said:
The question is:"Show that the Guassian curvature R of the surface of a cylinder is zero by showing that geodesics on that surface suffer no geodesic deviation." Now if I write down the deviation geodesic equation I get:
[tex]\frac{d^2\chi}{ds^2}+R\chi=0[/tex] where chi is the distance between geodesics, now because the cylinder has a quasi rectangular shape, the geodesics which start parallel stay parallel thus there is no geodesic deviation, and R=0 cause [tex]\frac{d^2\chi}{ds^2}=0[/tex] and xsi is linear wrt s chi=as+b so R=0. Is this just plain mambo jambo from my behalf or there's something genuine here?
It's a bit mumbo-jumboish, because you've essentially just re-stated the premise of the question. MTW ask you to show that geodesics on the surface of a cylinder suffer no geodesic deviation, and your answer is "because the cylinder has a quasi rectangular shape, the geodesics which start parallel stay parallel thus there is no geodesic deviation". It isn't clear what you mean when you say "the cylinder has a quasi rectangular shape", nor have you explained why geodesics on a surface with such a shape suffer no geodesic deviation.
Maybe what you mean is that we can "unroll" a cylinder and lay it flat on a table, without changing any of the internal surface distances, so it is a metrically flat surface, but this is really a third argument for flatness. It depends on what kind of answer you want. Most likely MTW expect you to determine the geodesic equations for a cylindrical surface and show explicitly that there is no geodesic deviation. That would be "something genuine".
[MTW also ask:] "Give an independent argument for the same conclusion by employing the formula
[tex]R=\frac{1}{\rho_1 \rho_2}[/tex] where [tex]\rho_1[/tex] and [tex]\rho_2[/tex] are the principal radii of curvature at the point in question wrt the enveloping euclidean 3-dimensional space." I am not sure about the second argument, which point is in question here?
Well, the minimum radius of a cylindrical surface is the usual raduis, whereas the radius perpendicular to that is infinite, and 1/infinity = 0, so the Gaussian curvature of the surface is zero.
Thank you for your post, I thought this thread of mine will get lost.
Anyway, back to topic, so I gather from your reply that I need to find parametric equation of the cylinder and from there show that the deviation is null, correct?
Well finding this parametric coordinates of the cylinder wouldn't be a problem.
If I have more questions I will ask them later one, thanks again for your reply.
  • · Replies 0 ·
  • · Replies 29 ·
  • · Replies 18 ·
