Impossible to graph position vs time?
The discussion revolves around the challenges of graphing position versus time for a body falling toward a black hole, exploring the implications of gravitational forces and the role of classical mechanics versus general relativity. Participants examine the mathematical complexities involved in modeling this scenario, including the effects of infinite forces and differentiability.
  • One participant describes the dynamics of a body falling into a black hole, emphasizing the increasing acceleration and velocity, and suggests that this leads to an infinitely differentiable position versus time graph.
  • Another participant argues that infinite differentiability is not inherently problematic, citing the example of the exponential function, and suggests that classical laws of physics break down near a singularity.
  • A third participant notes that classical metrics yield invalid results compared to general relativity, indicating a need for a different approach.
  • One participant questions whether it is necessary to use relativity and expresses skepticism about its implications, while also stating a belief that graphing is possible without it.
  • Another participant asserts that their differential equation should yield a position versus time function, but acknowledges limitations near the singularity.
  • Some participants express frustration, suggesting that it seems impossible to graph position versus time without using numerical methods like Euler's method.
  • Mathematical expressions are shared, indicating attempts to derive relationships between gravitational force, position, and time.
Participants do not reach a consensus on whether it is possible to graph position versus time without using numerical methods or the implications of relativity in this context. Multiple competing views remain regarding the applicability of classical mechanics versus general relativity.
There are unresolved mathematical steps and assumptions regarding the behavior of forces as distance approaches zero, as well as the applicability of classical mechanics in extreme gravitational fields.
leok
picture a body falling toward a black hole.
at the center of the black hole you have an infinite amount of force pulling you toward the center: F=Gm1m2/x^2 while x=0. F=infinity
so at a certain distance away from the black hole you have a certain force pulling you in.
but as you approach the center your acceleration increases.
but as you accelerate your velocity increases
so you were once not moving at you initial position. after a few seconds you start moving due to the force pulling you in.
but what happens is you gain velocity so now your acceleration is increasing.
but since you are accelerating your velocity starts to jerk.
the jerk effects the acceleration and you get a cycle of one derivative influencing the next.
so the position vs time graph becomes infinitely differentiable.
if you look at it in terms of energy:
work=force x distance
so Kinetic energy would be the integral of f=Gm1m2/x^2
your velocity is the square root of 2 times the integral
if change in momentum=impulse
m x dv= f x t
we have m2 x our velocity = f x t
we have force for a given X but not a given T so we cannot integrate Gm1m2/x^2
so to be able to graph x vs t we need f vs t
please help if you have any insight
Astronomy news on Phys.org
The "infinite differentiability", as you call it, isn't a problem in and of itself. Take the function [tex]e^{x}[/tex] for example. This is a similar case, and yet clearly it is graphabe.
Your problem is not really unique to black holes, however. Any body will produce this effect. The fact that the force of gravity goes to infinity as the distance goes to zero is mooted by the fact that our laws of physics (classical laws, at least) do not work after a certain point so we cannot describe that.
I think the energy equation you were talking about is this:
[tex]\int\frac{Gm_{1}m_{2}}{r^{2}}dr=\frac{m_{2}v^{2}}{2}[/tex]
But this equation is rather useless. If we assume a singularity, a force will be felt by the infalling object will increase without bound as r approaches zero, which it can. Since the singularity has no size, there is no boundary to stop the gravitation. Therefore, the gravitational potential energy would be infinite.
I would write something more along the lines of:
[tex]F=ma[/tex]
[tex]\frac{Gm_{1}}{r^{2}}=a[/tex]
[tex]\frac{Gm_{1}}{r^{2}}=\frac{d^{2}r}{dt^{2}}[/tex]
Classical metrics do not apply, and, yield invalid results compared to general relativity - as Nabeshin noted.
so the graph x vs t impossible to graph with a function?
and yes i realize this is not unique to black holes i was just trying to get ppl's attn
is it necessary to use relativity?
if so wouldn't that make relativity no longer a theory but rather a law?
i do however think it is possible to graph without relativity. i just haven't been able to incorporate time into my equation where time is my independent variable. LOLwhat i am really trying to get at is if i have a body at a certain distance from a planet there is no function that will tell me the time it takes to get there. HA! such a simple question to ask. (and i refuse to use euler's method- that %error is gross)(Also if it is solvable using relativity then the same scenario applies to forces and test charges-bam! i said it first XD... just kidding i don't think its relativity that we need)
The differential equation I gave should yield an explicit position versus time function. It just won't work all the way to the singularity.
Relativity won't help, because although it may predict a singularity, it doesn't help to describe it. Relativity would, however, likely yield a better answer to the problem, simply because Newtonian mechanics are merely an approximation which will become more obvious as the gravitational field of the black hole (or other celestial body) increases.
well your differential equation does not work the way i did it.
it yeilds t=abs(x) which i know isn't right
im still working on it so ill get back to this post soon
yeah i got nothing.
seems it is impossible to graph position vs time without the euler method
leok said:
yeah i got nothing.
[tex]Gm_{1}dt^{2}=r^{2}d^{2}r[/tex]
[tex]\int \int Gm_{1}dt^{2}=\int \int r^{2}d^{2}r[/tex]
  • · Replies 22 ·
