Explanation for the discrepancy in points for part A and B.
  • Thread starter Thread starter Dreamshot
    Physics Physics c
The discussion centers on calculating the spring constant (k) of an elastic cord and determining the mass (m) of an object based on experimental data. The student initially calculated k using the formula 1/2kx^2, resulting in a value of 21.3 N/m, but received only 2/3 points due to incorrect application of the formula. For part B, the student incorrectly used 1.5 m as the displacement (x) instead of the correct value derived from the initial height minus the distance fallen. The discussion emphasizes the importance of using the correct variables and formulas in physics problems.
  • Understanding of Hooke's Law and spring constants
  • Familiarity with energy conservation principles in physics
  • Knowledge of kinematics and dynamics of falling objects
  • Ability to manipulate algebraic equations for solving physics problems
  • Review the application of Hooke's Law in different scenarios
  • Study the principles of energy conservation in mechanical systems
  • Learn how to derive maximum speed using conservation of energy
  • Explore kinematic equations related to free-falling objects
Students studying physics, particularly those focusing on mechanics and energy conservation, as well as educators looking to clarify concepts related to spring constants and motion dynamics.
Dreamshot
In an experiment to determine the spring constant of an elastic cord of length 0.60 m, a student hangs the cord from a rod as represented above and then attaches a variety of weights to the cord. For each weight, the student allows the weight to hang in equilibrium and then measures the entire length of the cord. The data are recorded
in the table below:
Weight (N) 0 10 15 20 25
Length (m) 0.60 0.97 1.24 1.37 1.64
a) Determine an experimental value for the spring constant k of the cord.
The student now attaches an object of unknown mass m to the cord and holds the object adjacent to the point at
which the top of the cord is tied to the rod, as represented above. When the object is released from rest, it falls
1.5 m before stopping and turning around. Assume that air resistance is negligible.
(b) Calculate the value of the unknown mass m of the object.
(c) i. Calculate how far down the object has fallen at the moment it attains its maximum speed.
ii. Explain why this is the point at which the object has its maximum speed.
iii. Calculate the maximum speed of the object.
In part A I used 1/2kx^2. 10 N = 1/2k(.97)^2. I calculated it out and got k=21.3 N/m. My instructor gave me 2/3 points on this part. Why?
In part B I set Uel equal to U. 1/2kx^2 = mgh. I used 1.5m as x, which was circled on my paper as wrong. What should I have used?
2/3 possible points on A, as described above.
2/3 possible points on B, as described above.
0 points on C i
0 points on C ii
0 points on C iii
Thanks for any help!
Dreamshot: h = cord initial length (mass initial height) = 0.6 m. In part a, use F = k*x, not spring strain energy. Therefore, 10 N = k*(0.97 m - h). Average all four measured points. In part b, m*g*(h - x4) = 0.5*k*x4^2, where x4 = h - 1.5 m. For part c.i, d = distance fallen = h - x3, where x3 = -m*g/k. For part c.ii, there is a net force downward for any position above this position. For part c.iii, use conservation of energy to solve for the velocity when the mass is at the position stated in part c.i. Thus, m*g*h + 0 + 0 = m*g*x3 + 0.5*m*v3^2 + 0.5*k*x3^2.
Try it again and see if you get correct answers for all five questions now.
Do all values of the weight and length give the same value for k?
What does x represent?
