| Thread Closed |
High speed actuation |
Share Thread | Thread Tools |
| Jan29-09, 07:59 AM | #1 |
Hi All,
I need a actuation system which will rotate the 80mmx100mmx4mm plate from 0-45 degrees, pivot point @ one end of the plate. I need the time for moving it to 45 degree and back to the original position will be 40 milli-seconds including the response time of the actuator. Here we can use the linear actuator and convert the linear motion into rotary motion. Please suggest the actator for this application. Thanks in advance...... |
| Jan29-09, 09:36 AM | #2 |
Will this movement be a repetitive motion?
| Jan30-09, 02:59 AM | #3 |
| Jan30-09, 04:20 PM | #4 |
You could just use a simple encoded motor or stepper motor, similar to what is used for windshield wipers on a car.
| Jan31-09, 03:31 AM | #5 |
Windscreen wiper motor won't act in 40ms.
How about something like this: http://www.heinzmann.de/index.php?op...id=126&lang=en Probably too big and torquey for your application but it gives you an idea of what's available. |
| Jan31-09, 10:35 AM | #6 |
Recognitions:
40 ms for the entire trip is pretty fast. Have you thought of using compressed air jets to do this? I have seen this method used on quite a few production lines.
| Jan31-09, 04:33 PM | #7 |
| Feb1-09, 01:39 PM | #8 |
Recognitions:
The assumption I work under is that most plants already have a compressed air capacity that is used all over the plant. That may or may not be the case.
| Feb8-09, 05:13 AM | #9 |
In this particular application, components are moving in that flapper. And this flapper is located in betwen the 2 conveyors.I can not able use the air jet for the reason that orientation of component may change or the speed of motion of component will increase. I have already tried with the pneumatic actuator and with the pneumatic muscle. I have achieved up to 120 milli seconds. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: High speed actuation
| high speed winch | Engineering Systems & Design | 3 | ||
| Efficiency of RWD vs. AWD at high speed | Mechanical Engineering | 37 | ||
| Collisions at high speed vs normal speed | General Physics | 5 | ||
| High speed collisions | Special & General Relativity | 2 | ||
| High Speed Energy | Quantum Physics | 4 | ||
