Calculating Aeroplane Speed and Archer's Bow Work: Physics Problems Solved
  • Thread starter Thread starter DNA
The discussion revolves around two physics problems: calculating the speed of an aeroplane under specific forces and determining the spring constant and work done in an archer's bow. The subject area includes dynamics and mechanics, particularly focusing on forces, motion, and energy concepts.
  • Mixed
  • Participants explore various methods to calculate the spring constant for the bow and the work done in pulling it back. There are attempts to apply Hooke's Law and energy principles. For the aeroplane, discussions include calculating net forces and using kinematics to find final speed after a distance.
Some participants have provided guidance on how to approach the problems, including equations and relationships between forces and motion. There is an ongoing exploration of the archer's bow problem, with corrections noted in calculations. The aeroplane problem is also being revisited with emphasis on initial conditions and assumptions.
Participants are working under the constraints of homework guidelines, which may limit the depth of assistance provided. There are also mentions of potential clerical errors in calculations that participants are addressing.
DNA
Can someone please help me with the following?
An aeroplane of mass 1.5 x 104 kg is moving at 60ms-1.
The pilot then revs up the engine so that the forward thrust of the propeller becomes 7.5 x 104 N. If the force of the air resistance has a magnitude
of 4.0 x 104 N, find the speed of the aeroplane after it has traveled 500m. Assume that the aeroplane is in level flight throughout this motion.
An archer pulls her bow string back 0.400m by exerting a force that increases uniformly from zero to 230N.
a) What is the equivalent spring constant of the bow?
b) How much work is done in pulling the bow?
What have you tried to do to solve these problems?
The Archer problem
To solve part a.)
k= mg / d So d = 4.000 meters and m= 230 Netwons
Note that 1 kg = 9.8 Newtons. Therfore, 226 N = 23.469 kg .
Now plug in and solve for k = (( 23.469 kg ) * ( 9.8 m/s^(2)))/ ( 4.000 m ) = 57.5 N/m
Correction Therefore 230 N = 23.469 kg
ccwitt said:
The Archer problem
To solve part a.)
What are you doing?
[tex]PE_{spring} = \frac{1}{2}kx^2 = W_{spring}[/tex]
[tex]F_{spring} = kx[/tex]
to answer part a, just sub into the force equation and solve for k. To answer part b, use Work formula I wrote. As for the first question, just subtract your thrust force from your air resistance force, and then you have your net force. You have mass, so you can slove for acceleration. Once you have this, use the kinematics formulas to solve for final speed.
Regards,
Nenad
Nenad said:
What are you doing?
Regards,
Nenad
In part a.) it works the same a a spring vertically hung undergoing a load "mg" with a distance d.
In the case of the Archer we just apply Hooke's Law like in a spring to give
|F (sub s) | = k*d = mg this implies k = mg/d
So in part a.) Its really k = 230 N / 0.400m =575 N/m This is a clerical error made by myself because I was in a hurry. I should have been more carefull in writing the response.
and as for the aeroplane...
you have the initial velocity of the plane, you have the new tractive force of the engine/propeller minus the air resistive force of the plane, you have f=mA, a=dv/dt, and some other things to get you to from the initial speed to the final speed, how long it took to go 500m and you can assume all other things you want, including ignoring gravity...
:smile:
10K
