Another problem involving computing area with integrals
The problem involves computing the area of a region enclosed by the curves defined by the equations x + y^2 = 6 and x + y = 0. Participants are exploring the appropriate method for integration, considering whether to integrate with respect to x or y.
  • The original poster attempts to integrate with respect to x, setting up an integral based on their sketch of the curves. Some participants suggest reconsidering the integration approach, proposing that integrating with respect to y may simplify the problem.
The discussion includes various interpretations of the integration method, with one participant providing an alternative approach that yields a different area result. There is acknowledgment of the complexity involved in choosing the correct method, and some guidance has been offered regarding the integration setup.
Participants note the intersection points of the curves and the challenges posed by changing functions when integrating vertically. There is mention of a similar problem discussed previously, which may influence the current discussion.
haydn
Sketch the region enclosed by the given curves. Decide whether to integrate with respect to x or y. Then find the area of the region.
x+y^2=6
x+y=0
none, just using integrals...
I sketch the two curves and find they intersect at x=-3 and x=2. Looking at it I want to integrate with respect to x.
y=[tex]\sqrt{-x+6}[/tex] appears to be the top function, while y=-x is the lower function.
I set up an integral from -3 to 2 that consists of: [tex]\sqrt{-x+6}[/tex] - (-x) dx.
I evaluate using substitution and keep getting 10.16, which the homework website I'm using says is wrong. Not sure what I'm doing incorrectly here.
It's a lot easier if you integrate w.r.t y (i.e., use horizontal area elements rather than vertical elements). If you do it this way there are no radicals to deal with. The area I get is 49/3.
You can find the area using vertical area elements, but the y values at the bottoms of your area elements change. For one interval, the function at the bottom is y = -x; for the other interval, the function at the bottom is y = -sqrt(-x + 6). This means that your formula for the area of the typical element has to change, and that means you need to integrals.
BTW, this problem is very similar to the one posted yesterday by vipertongn.
Hey thanks a lot. I get it now. I got the correct answer.
  • · Replies 27 ·
