Accelerations of Boxes on a Horizontal Surface
  • Thread starter Thread starter sci-doo
    Accelerating
The problem involves two boxes, where box 1 is placed on top of box 2, which is on the floor. The scenario describes the effect of a horizontal force applied to box 1, leading to sliding due to kinetic friction between the boxes and between box 2 and the floor. The question seeks to determine the accelerations of both boxes under these conditions.
  • Exploratory, Assumption checking
  • Participants discuss the forces acting on both boxes, including the effects of kinetic friction and the implications of Newton's third law. There is exploration of limiting cases and the conditions under which box 2 might move.
The discussion is ongoing, with participants questioning the assumptions about the movement of box 2 and the nature of the forces involved. Some guidance has been provided regarding the relationship between the forces acting on the boxes, but no consensus has been reached regarding the accelerations or movements of the boxes.
Participants note the complexity introduced by the frictional forces and the mass of the boxes, leading to confusion about the potential for negative acceleration or movement in the opposite direction. There is an acknowledgment of the need to clarify the conditions under which box 2 would remain stationary or move.
sci-doo
Box 1 is placed on box 2, which sits on the floor. Kinetic friction constant between the boxes, and the box 2 and the floor, is equal u.
When box 1 is pushed with horizontal force F it starts to slide on box 2. At the same time, box 2 starts to move. What are the accelerations of the boxes.
Kinetic friction Fk=ukN
F=ma
The top box (box 1):
Force that accelerates (pushing minus friction)
Fa=F-Fu=F-ukN
and the acceleration
a=[tex]\frac{F-u_{k}N}{m_{box1}}[/tex]
The lower box (box 2):
By the Newtons 3rd law the force that pushes the box 2 is the reaction of kinetic friction Fu between the boxes, right? Now this is where I face the problem: as the friction between box 2 and floor is the same but the weight is more (box1+box2) I get negative acceleration ?!? :cry:
Consider the limiting cases: The second box on a frictionless surface, and the second box fastened to the surface such that this box cannot move.
Welcome to PF.
Your kinetic friction arises because it is moving relative to the box underneath.
Now Kinetic friction is a retarding force given by the μ *m*g relationship.
The maximum force then that Box 1 can transfer to box 2 is just that.
As you note though box 2 has a retarding force available of μ *(m + m) * g.
Since μ *(2m)*g will always be > μ *m*g then I have serious doubt that the bottom box moves despite the statement of the problem. So I'd say it's not negative acceleration, just 0 movement.
Makes sense.
I don't see how it could move (especially to opposite direction)... I think it'd move (to positive drctn) only if the weight was <0 ...
9K
