Cauchy Sequence That Does Not Converge In A Space
  • Context: Graduate
  • Thread starter Thread starter azdang
    Cauchy Sequence Space
The discussion revolves around finding a Cauchy sequence within a specific subspace of l^infinity, denoted as M, which consists of sequences with at most finitely many nonzero terms. Participants are exploring the properties of such sequences, particularly focusing on constructing a Cauchy sequence that does not converge within M, thereby demonstrating that M is not complete.
  • Exploratory, Technical explanation, Debate/contested, Mathematical reasoning
  • One participant asks for ideas on constructing a Cauchy sequence in M that does not converge in M.
  • Another participant suggests that the limit of the sequence must have infinitely many non-zero terms, which would disqualify it from being in M.
  • There is a discussion about the boundedness of sequences in M, with some expressing confusion about the requirements for sequences in l^infinity.
  • Participants propose specific sequences, such as (0, 0, 0, ...) and (1, 1, 1, ...), and discuss their properties regarding convergence.
  • One participant expresses difficulty in understanding how to show incompleteness and the nature of Cauchy sequences.
  • There is a clarification that showing incompleteness is easier than completeness, as it only requires finding one Cauchy sequence that does not converge.
  • Participants discuss the implications of sequences converging to limits that may or may not belong to M, highlighting the distinction between convergence in l^infinity and in M.
  • One participant points out that having infinitely many zeros does not necessarily imply having finitely many nonzero terms, using an example to illustrate this point.
  • A final suggestion is made regarding a Cauchy sequence in a different space, R \ {0}, which does not converge in that space.
Participants generally agree on the need for a Cauchy sequence that does not converge in M, but there are multiple competing views on how to construct such a sequence and the implications of convergence in relation to M. The discussion remains unresolved regarding the exact sequence to use and the nuances of completeness.
Some participants express confusion about the definitions and properties of sequences in M and l^infinity, indicating potential limitations in understanding the problem's requirements. There are also unresolved questions about the nature of convergence and the specific characteristics of sequences being discussed.
azdang
Let M be a subspace of l^infinity consisting of all sequences x = (x_j) with at most finitely many nonzero terms. Find a Cauchy sequence in M which does not converge in M, so that M is not complete.
Does anyone have any ideas what to use for a Cauchy sequence that does not converge in M? I've been trying to think of something, but I can't come up with anything. Thanks.
If I understand the question correctly, you need a sequence where each element xj has only finitely many non-zero terms (i.e. for every j there are only finitely many i such that (xj)i is not 0), but the limit
[tex]x {:=} \lim_{j \to \infty} x_j[/tex]
has infinitely many (i.e. there are infinitely many i such that (x)i is not 0).
Yes, at least that's what I thought, too. The question is out of my book for Real Analysis. I've been unable to come up with anything though. And also, since M is a subspace of l^infinity, I'm guessing any sequence in M has to be bounded, too? I'm not really sure, I'm reallyyy confused by this question.
So the obvious sequence with only finitely many non-zero elements is the sequence consisting only of 0: (0, 0, 0, 0, 0, 0, ...), so you can take that as the first element.
A simply sequence with infinitely many non-zero elements would be one that only consists of 1's; (1, 1, 1, 1, 1, 1, 1, 1, ...).
Is it in l_infinity? Then you can take that as your limit... any thoughts as how to get from one in the other (in infinitely many steps, but each step only removing finitely many zeroes)?
I think I was trying to think of something along these lines, but I was getting no where because I still was unsure how to construct the sequence. What did you mean by this: Is it in l_infinity? Then you can take that as your limit
Thanks for your help :)
Sorry, it doesn't need to be in l_infinity. It just has to be outside of M, which is obviously is.
With "then you can take that as your limit" I meant that it is a good candidate for the sequence x to which your sequence of sequences [itex]x_j[/itex] converges.
So, if the sequence was like (0,0,0,...), then (1,0,0,0,...), (1,1,0,0,0,...)...does that ultimately converge to (1,1,1,1,...) and work for my problem? I'm not sure I'm getting it right.
That's a sequence I had in mind... showing that it converges and works for your problem is up to you :smile:
Seriously, do you know how to prove convergence with the metric on l_infinity? Or is it the concept of sequences of sequences you're having trouble with?
If you have a sequence of sequences x_i, then what is the difference between two of them, e.g. what is |x_4 - x_2| ?
I'm honestly not even sure what's causing me trouble. I think it's the whole idea of trying to show something is incomplete, as oppose to complete, because I have absolutely no trouble proving something is COMPLETE. But thank you again for all of your help, I'm going to try to apply this to my problem.
Actually showing incompleteness is easier, because instead of taking a general Cauchy sequence and showing that it converges, you only have to find a single Cauchy sequence which does not converge.
Anyway, I think you'd rather use
(0, 0, 0, 0, ...)
(0, 1, 0, 0, ...)
(0, 1, 1/2, 0, ...)
(0, 1, 1/2, 1/3, 0, 0, ...)
or something like that, because when you use just 1's it doesn't converge while this does (as you'll find out).
l^inf is the space of bounded sequences, so (1, 1, 1, ...) is in l^inf.
Yes, but it is not in the set of sequences in l^inf with at most finitely many nonzero terms.
And the reason (1, 1, 1, ...) doesn't work is that the sequence
(0, 0, 0, ...)
(1, 0, 0, ...)
(1, 1, 0, ...)
(1, 1, 1, 1...)
doesn't converge in l^inf, I think (the l^inf-distance between any two distinct elements is 1).
Ah yes, you're right.
(0, 0, 0, 0, ...)
(0, 1, 0, 0, ...)
(0, 1, 1/2, 0, ...)
I'm a little confused, when a sequence like this converges, isn't it going to converge to a sequence with 0 as its first term. And then, isn't this limit in M? Sorry! I'm having a really hard time visualizing it.
M is the set of sequences with finitely many nonzero terms. In l^inf, it will converge to the sequence (0, 1, 1/2, 1/3, 1/4, ...), which has infinitely many nonzero terms (only the first term is zero).
(The zero term at the beginning isn't necessary; you may as well work with (1, 1/2, 1/3, ...).)
The kind of formulation used in the question takes some time getting used to.
"At most finitely many non-zero terms" means that there are infinitely many which are zero.
That is, for a sequence x with elements x1, x2, x3, ..., xi, ...
[tex]x \in M \iff \{ i = 0, 1, 2, \cdots | x_i \neq 0 \} \text{ is finite} \iff \{ i = 0, 1, 2, \cdots | x_i = 0 \} \text{ is infinite}[/tex]
Clearly,
(0, 1, 1/2, 1/3, ...)
(1, 1/2, 1/3, 1/4, ...)
or even
(0, 0, 0, 0, ..., 0, 1, 1/2, 1/3, 1/4) [with any finite number of zeroes added at the beginning)
are not in M then, because you only have finitely many which are zero.
Gotcha. Thank you SO much for all of your help. I really appreciate it.
Careful. Having infinitely many zeros doesn't imply having finitely many nonzero terms. Consider the sequence (0, 1, 0, 1, 0, 1, ...)
Consider the sequence 1, 1/2, 1/3, ... in the space X = R \ {0}. This is a Cauchy sequence in X which does not converge in X.
  • · Replies 24 ·
