Calculating external work done in electric field
The problem involves calculating the external work done on a charged sphere moving within a uniform electric field. The electric field strength is given as 10.0 V/m directed due east, and the sphere has a charge of +50.0 nC. The sphere is moved through a series of specified distances in various directions, raising questions about how to account for the direction of movement relative to the electric field.
  • Participants discuss the relationship between the direction of movement and the work done, particularly focusing on movements that are perpendicular to the electric field. There are attempts to clarify how to calculate work when moving in the same direction as the field versus perpendicular to it.
Some participants have provided insights regarding the nature of work done in relation to the electric field, noting that work is zero when movement is perpendicular to the field. Others are exploring the implications of moving in the direction of the field and questioning the sign of the work done. There is ongoing discussion about the relationship between work and potential energy changes.
Participants are considering how the movement of the charge affects its potential energy and the implications of the electric field's direction on the work done. There are also references to potential changes and the relationship between work and voltage in the context of the electric field.
winterwind
A region of space has a uniform electric field of strength 10.0 V/m due east. A small metal sphere with charge of +50.0 nC is in the field. There sphere is moved at a constant speed by an external force 10 cm north, 50 cm east, 20 cm south, and 50 cm east. How much work was done in total by the applied force?
W = qEs
W = qE, so I tried to plug in the charges and electric field information. But I don’t know how to apply the fact that the electric field is directed due east. I can calculate the work if it were moved AGAINST the electric field, but I don’t know how to calculate it if it were moved in the same direction as the electric field or perpendicular to it, as in this case.
The total work is just the sum of all the individual work required to move the charge each time.
Thanks for your help!
If you have a force that's perpendicular to the direction of motion it does no work. It's the same for this. W=qEs, but F=qE, so W=Fs. If you apply the force perpendicular to the field, it does no work. So you only have to consider the east movements.
Thanks.
The work is the same if I move it x amount east or x amount west, with the field due east?
Part two of the question: What is its change in potential?
Attempt:
Would the change in potential just be the amount of work done? Or is it zero since it is in the same electric field?
Yes, the magnitude of work will at least be the same. I'm not 100% sure about it being positive or negative, but it's early in the morning and I can't think properly.
No, Work= negative change in potential energy. Potential energy is related to potential.
If you are moving in the direction of the force then you have (-) work.
Like for instance gravity going down gives back -work as kinetic energy.
With work being given by the relationship:
W = q*ΔV
and your field given as 10v/m, if you move in the direction of the field you are moving toward lower voltage at the rate of 10v/m. So if you move 50cm + 50 cm toward negative voltage, your voltage will be lower by what amount? Since the ΔV is negative then your work should be negative shouldn't it?
  • · Replies 22 ·
