Electric & Gravitational Fields
The discussion focuses on calculating the electric field strength created by a gold nucleus at a distance of 1.5x10^-17 meters from an alpha particle. The correct formula to use is E = kq/r^2, where k is the Coulomb's constant, q is the charge of the nucleus, and r is the distance. The provided answer of 5.2 x 10^22 Vm^-1 aligns with this calculation. Participants emphasize the importance of memorizing key formulas related to electric fields to efficiently solve such problems.
  • Understanding of electric fields and forces
  • Familiarity with Coulomb's law and its applications
  • Knowledge of the concept of relative permittivity
  • Basic algebra for rearranging equations
  • Study Coulomb's law and its implications for electric fields
  • Learn about electric potential and its relationship to electric fields
  • Explore the concept of relative permittivity in different media
  • Practice problems involving electric fields and forces on charges
Students studying electromagnetism, physics educators, and anyone preparing for exams involving electric fields and forces.
mandos
(Prior to start of questions, it informs me the relative permittivity of free space is 8.9x10^-12)
2) An alpha particle (charge 3.2x10^-19) approaches to a distance of 1.5x10^-17 from a gold nucleus (charge 1.3x10^-17). Calculate:
a) the strength of the field created by the gold nucleus at the distance of the alpha particles closest approach.
2. Homework Equations + Attempt at a solution
According the back of the book, the answer is 5.2 x 10^22 Vm^-1
Because it gave me the relative permittivity of free space, I tried using that (even though it could be for other questions, like question 1, where I needed it).
So I used F= Q1,Q1 / 4xPiex8.9x10^-12xr^2
Where I used the two charges provided and I used the distance as the radius (r).
That didn't work.
So I assumed that due to the units the back of the book gives (Vm^-1), the right equation to use would be V= Ed. But, if I rearrange is to get E .. I don't have the value of V.
But I do still think that V = Ed is barking up the right tree. But how do I find V? W = VQ? But how do I know W?
The problem is, I can't think of any other equations that are suitable to use, apart from the above two that I've discussed.
Any help would be much appreciated.
It is very inefficient to try finding the right formula by considering the units. Far better to get to work and memorize what each of your formulas is for. For electric field, you just have about 3 of them:
1) V = Ed which should be thought of as E = V/d
This one says, "a potential difference causes an electric field between parallel plates"
2) F = Eq which says "an electric field causes a force on a charge"
3) E = kq/r^2 which says "a charge causes an electric field around itself"
(here the k may be replaced with 1/(4*pi*epsilon) in your book)
Study all three! Then when you read your problem again and think about how you are asked what E field the charge on a nucleus causes, you will INSTANTLY know the right formula to use!
  • · Replies 26 ·
  • · Replies 22 ·
  • · Replies 16 ·
