What etching agent should I use for Al 3104?
  • Thread starter Thread starter darkelf
    Aluminium Etching
The appropriate etching agent for Al 3104 is critical for revealing its microstructure. Keller’s reagent, composed of 95 mL water, 2.5 mL HNO3, 1.5 mL HCl, and 1.0 mL HF, is a widely used general-purpose etchant for aluminum and its alloys, excluding high-silicon variants. For specific grain size analysis in wrought alloys such as 2XXX, 3XXX, 6XXX, and 7XXX, Graff and Sargent’s etchant is recommended, consisting of 84 mL water, 15.5 mL HNO3, 0.5 mL HF, and 3 g CrO3. Safety precautions, including the use of a fume hood and personal protective equipment, are mandatory when handling these chemicals.
  • Understanding of metallographic polishing techniques
  • Familiarity with chemical safety protocols
  • Knowledge of aluminum alloy classifications
  • Experience with etching reagents and their applications
  • Research Keller’s reagent and its applications in aluminum etching
  • Study Graff and Sargent’s etchant for grain size analysis
  • Learn about the properties and uses of fluoboric acid in anodizing
  • Investigate safety measures for handling hydrofluoric acid (HF)
This discussion is beneficial for metallurgists, materials scientists, and laboratory technicians involved in aluminum alloy processing and analysis.
darkelf
I am made to understand that you are meant to use different etching agents for different aluminum alloys. How does one find which etching agent is the right one for each alloy?
Does anyone know what etching agent I can use for Al 3104?
Thank you
Try Samuels' Metallographic Polishing by Mechanical Methods, whence comes the following information:
LIGHT METALS - Aluminum and Alloys
Composition Comments
  1. 95 mL water, 2.5 mL HNO3, 1.5 mL HCI, 1.0 mL HF: Keller’s reagent, very popular general purpose reagent for Al and Al alloys, except high-Si alloys. Immerse sample 10-20 seconds, wash in warm water. Can follow with a dip in conc. HNO3. Outlines all common constituents, reveals grain structure in certain alloys when used by immersion.
  2. 90-100 mL water, 0.1-10 mL HF: General-purpose reagent. Attacks FeAl3, other constituents outlined. The 0.5% concentration of HF is very popular.
  3. 84 mL water,15.5 mL HNO3, 0.5 mL HF, 3 g CrO3: Graff and Sargent’s etchant, for grain size of 2XXX, 3XXX, 6XXX, and 7XXX wrought alloys. Immerse specimen 20-60 seconds with mild agitation.
  4. 1.8% fluoboric acid in water Barker’s anodizing method for grain structure. Use 0.5-1.5 A/in2, 30-45 V dc. For most alloys and tempers, 20 seconds at 1 A/in2 and 30 V dc at 20 °C is sufficient. Stirring not needed. Rinse in warm water, dry. Use polarized light; sensitive tint helpful.
A fume hood and personal protective equipment is mandatory. Don't go near HF unless you fully understand the associated hazards, are fully protected, and have calcium gluconate on hand.
  • · Replies 0 ·
