Lorentz force: absolute reference frame?
The discussion revolves around the Lorentz force and the concept of an absolute reference frame in the context of electromagnetism. Participants explore the relationship between velocity, magnetic fields, and reference frames, questioning the nature of magnetic forces and their dependence on relative versus absolute velocities.
  • Some participants assert that the magnetic field is dependent on the velocity of charges relative to the frame in which electric and magnetic fields are measured.
  • Others question the existence of an absolute reference frame, suggesting that all frames are valid and that results will remain consistent across different inertial frames.
  • There are claims that the magnetic potential vector field increases with "absolute velocity," which some participants challenge as an assumption.
  • Participants discuss the implications of two parallel electrons moving at the same velocity and whether they experience attraction without relative velocity, raising questions about the nature of magnetic and electric forces in different frames.
  • Some argue that the equations governing magnetic forces, such as F= q(v x B), are clear and supported by experimental evidence, while others suggest that the equations may not be correctly applied in certain contexts.
  • There is mention of the electromagnetic field tensor and how E and B fields transform under Lorentz transformations, indicating a complex interplay between electric and magnetic fields in different reference frames.
  • One participant suggests that the magnetic field for a moving charge should be described using the Lienard-Wiechert potentials, indicating a potential disagreement on the appropriate models to use.
Participants express multiple competing views regarding the nature of reference frames in electromagnetism, with no consensus reached on the existence of an absolute reference frame or the interpretation of magnetic forces in specific scenarios.
Some participants highlight that measurements in experiments are made in the frame of the measurer, emphasizing the relativity of observations. There are unresolved questions about the assumptions underlying the claims regarding absolute velocity and the nature of forces between parallel moving charges.
mangoos
F= q(v x B)
B= v x q*k*d/r^2
It is a basic physics knowledge magnetic field forms around moving charge, it tell us magnetic field is zero when charge is not moving and strength of magnetic field increases as velocity increases, right? Magnetic potential vector field increases with "absolute velocity", not relative velocity. Perhaps I got the equations wrong, but if not what is that velocity relative to, Aether?
Two parallel wires:
http://www.magnet.fsu.edu/education/tutorials/java/parallelwires/
1.) velocity relative to field?
2.) velocity relative to wires?
Velocity is with respect to the frame in which E and B are measured.
What exactly is that frame, aether? Why two parallel electrons, without any relative velocity, attract more the faster they are going? You see the equations? There is no any relative velocity there, just "individual" velocity. - "Two electrons traveling in parallel with the same velocity, without any relative velocity, will attract more the faster they are moving." Do you know about this, you do not know or you claim is false? This Java applet demonstrates well known and easy to test experiment about Lorentz attraction and Ampere's law: http://www.magnet.fsu.edu/education/tutorials/java/parallelwires/
Parallel wires, what is the frame of reference:
2.) velocity relative to wires? Free parallel electrons (cathode ray), what is the frame of reference:
2.) velocity relative to aether /absolute_reference_frame /fixed_stars?
In different inertial reference frames, the two currents or charges produce different mixtures of E and B fields, such that the net effect is the same, after taking length contraction and time dilation into account where necessary.
The E and B fields transform together as a tensor (the electromagnetic field tensor) under the Lorentz transformation.
Sounds like this is an assumption you are making?? just not true.
Vanadium, post # 2, IS correct.
If you fire a test charge with a velocity v relative to a point which has a magnetic field present, a sideways magnetic force acts on the particle. As the velocity (between the particle and the magnetic field at the point) decreases so does the force F. If the particle sits still at the point relative to the magnetic field, there is no force F (v is zero)...does that help??
Alternatively, you can complicate the whole scene and use any other reference frame and if you account for the relative motions can still arrive at a correction solution...but the fact that there is NO absolute reference frame means you can pick an easy one and work your solution from that one you chose...you will still get the correct answer because no frame is absolute...no frame is the "correct" frame...
If these answers are not clear, try the current thread nearby
"Is there the possibility of "absolute time" and check out the first page or so of posts...
For example, what is considered "magnetic force" with respect to one frame of reference, may look like "electric force" with respect to another frame of reference (or some combination of magnetic and electric force). However, there are some invariant values, which all observers should agree on, such as
[tex]2\left(\vec{B}.\vec{B}-\frac{\vec{E}.\vec{E}}{c^{2}}\right)[/tex]
or
[tex]\frac{4}{c}\vec{E}.\vec{B}[/tex]
mangoos said:
B= v x q*k*d/r^2
Your magnetic field for a moving charge is wrong. You have to use the Lienard-Wiechert magnetic field. Look at an advanced EM text.
I'm not talking about different inertial reference, but about two electrons traveling ALONG each other, in PARALLEL, without any relative velocity. What is relative velocity of two particles traveling in parallel?- "Two electrons traveling in parallel with the same velocity, without any relative velocity, will attract more the faster they are moving." - Do you know about this, you do not know or you claim is false?
Equations are clear about that: F= q(v x B); B= v x q*k*d/r^2
Experiments are clear about that:http://www.magnet.fsu.edu/education/tutorials/java/parallelwires/
I'm not making any assumptions, but observations. I'm talking about real world experiments and equations form textbooks.
What do you say is assumption? What is not true?
It is correct enough to demonstrate how it works, EXPERIMENTS CONFIRM THOSE EQUATIONS, this is general knowledge, high-school physics. This Java applet demonstrates well known and easy to test experiment about Lorentz attraction and Ampere's law: http://www.magnet.fsu.edu/education/...parallelwires/
2.) velocity relative to wires?Free parallel electrons (cathode ray), what is the frame of reference:
2.) velocity relative to ...?
In ANY experiment the measurements are made in the frame of the measurer !
This can be any frame you choose. The whole point of relativity is that the results will be the same in any inertial frame - you don't need an absolute frame.
Moderate your tone - I personally find your attacking style offensive.
is this true?
Experiments are clear about that:http://www.magnet.fsu.edu/education/...parallelwires/
is this true?
is this not what is is called "electron coupling" in chemistry and QM?
Hi Nancy57, welcome to PF,
It looks like the OP has already left, but I thought I should post this link about http://physics.weber.edu/schroeder/mrr/MRRtalk.html" .
It is a pretty interesting derivation. Basically, you can think of magnetism as simply being a consequence of length contraction for moving charges. It is really pretty amazing when you think that a typical drift velocity for an electron in a wire is on the order of mm/s or less, and yet electromagnetism is such a strong force that the miniscule length contraction even at such a small speeds can cause such easily measurable results.
In any case, the bottom line is that not only is magnetism completely compatible with relativity, but relativity unites electrostatics and magnetism in a very elegant manner, showing that they are simply "two sides of the same coin" in a way that simply cannot be appreciated without relativity.
"this is general knowledge, high-school physics."
That just means you have to go to graduate school or read an advanced EM text before you find out about the force between two moving charges.
Experiments are clear about that: http://www.magnet.fsu.edu/education/tutorials/java/parallelwires/index.html
DaleSpam,
hi, thank you. i see what you're saying, i learned the same at my uni and there is no question about "everything is relative", but if above statement is true, if experiments measure attraction of parallel electrons, then what does that mean, what is their relative velocity relative to? before talking about theory and relativity we need to know about experimental facts and whether above statement is true or false?
Wikipedia and my physics textbook used at Auckland University -"PHYSICS for Scientists and Engineers with Modern Physics, Serway-Beichner, 2001", confirms above statement. however, they do not talk about reference frames at all, so they do not say anything that would directly resolve the question, still they confirm formulas and experimental results, what does that mean?
[-edit-]
after 3-4 hours of searching the net i can not find any direct answers, however i double checked formulas and experimental studies with free electrons and electron beams, many of which speak of attraction, but still no mention of reference frames and why would electrons attract proportionally to their velocity, instead of their relative velocity.
however, i found this is actually an old argument between Lorentz and Einstein: "Lorentz contended against Einstein that there had to be a medium in which electro-magnetic waves exist and propagate, and that that would of necessity be an absolute frame of reference for the universe. Einstein won that dispute contending that electro-magnetic waves needed no medium and that there was no absolute frame of reference. But, that victory was in a conflict of Lorentz’s opinion opposed to Einstein’s opinion combined with Einstein’s substantial other successes and reputation. It was not a victory of solid reasoning nor demonstrated factual evidence... "
basically, i could not find any verified source and reference to address this question, can anyone provide concrete peer reviewed reference that addresses this particular case of Lorentz force, parallel electrons and reference frames?
Be careful here. This is not correct. When physicists say "X is relative" that means that X is a quantity which is frame variant, or in other words the value of X will be different in different coordinate systems. There do exist many things which have the same value in different coordinate systems. Such things are called "frame invariant" and are not relative. Examples of frame invariant quantities are the spacetime interval, proper time, invariant mass, etc.
I provided you a link above. The explanation you are looking for is in the section "transformation of electrostatic fields", but I would recommend reading the section "magnetism as a consequence of length contraction" first. The same author also has more extensive notes in .pdf form at http://physics.weber.edu/schroeder/mrr/MRRnotes.pdf
There is also http://farside.ph.utexas.edu/teaching/em/lectures/node106.html which is a more advanced treatment but has essentially the same information. You should especially look at the "Force on a moving charge" and the "Fields due to a moving charge" sections.
Once you feel comfortable with the link between the electric field, length contraction, and the magnetic field then if you still don't understand the specific case of two co-moving electrons I will be glad to help.
There is also http://farside.ph.utexas.edu/teachin...s/node106.html which is a more advanced treatment but has essentially the same information. You should especially look at the "Force on a moving charge" and the "Fields due to a moving charge" sections.
thank you, but those links actually confirm Lorentz force and Biot–Savart law even more. i already do feel very comfortable with all of it since I've been working in the field for the last five years, as a software engineer for numerical modeling and analysis of electromagnetic interaction. i suppose you are referring me to Einstein's "Lorentz transformations"?
i believe i already know everything about all that, but the answer i have does not make sense and i can not perform physical experiments myself. so, if you have an understanding with which you can answer the question, then please do:
Experiments are clear about that: http://www.magnet.fsu.edu/education/...res/index.html
according to your understanding, is this true or false?
Of course those links confirm the Lorentz force and Biot-Savart law! I am glad you feel comfortable with them, but I think you missed the whole point. The point was not to contradict Lorentz force law or Biot-Savart, but to derive them using relativity.
When they were initially developed they were the result of empirical data, with no understanding or connection to anything else. With the advent of relativity however it became possible to actually derive magnetism as a direct result of the postulates of relativity. Thus, magnetism is not only completely compatible with relativity, but is in fact an inevitable logical consequence of relativity.
So the point is that since magnetism is a logical consequence of the postulates of relativity it certainly cannot be logically used to claim the existence of an aether frame.
It is essentially correct, but poorly worded. Electrons are negatively charged and like charges repel, so two electrons repel each other. Due to relativity and magnetism (see the links I provided) the faster two co-moving electrons are traveling in a given inertial frame the less they repel in that frame. It is a direct consequence of length contraction, time dilation, etc.
thank you, we needed to agree on experimental facts. unfortunately, the length contraction and time dilation do not really address the obvious paradox, on the contrary, look how Wikipedia describes Lorentz transformation: "They form the mathematical basis for Albert Einstein's theory of special relativity. In 1905 Einstein derived them under the assumptions of the principle of relativity and the constancy of the speed of light in any inertial reference frame."
...what's worse, those formulas simply do not apply, nor work, while Lorentz and other classical physics equations work very well, they can actually model electron interaction and electron beams in magnetic field with the same results as experiments measure, stuff like this for example:
- can you point exactly what part about length contraction and time dilation explains the attraction of electrons traveling without any relative speed?
Citation to experimental evidence published in peer-reviewed scientific literature, please?
according to my understanding those equations simply do not apply.
are you saying 'Lorentz transformation' can be used to model individual electromagnetic interaction of moving charges? if anyone ever managed to document how to model interaction of moving charges using those formulas, published in peer-reviewed scientific literature, please let us know.
Relativistic electrodynamics can handle the problem and shows that there is no paradox. All intertial observers will see the same outcome. It's in any good textbook on the subject.
Try reading some books instead of cherry-picking ambiguous statements from web-sites.
See for example chapter 12 of Griffiths, "Introduction to Electrodynamics."
  • · Replies 55 ·
  • · Replies 87 ·
  • · Replies 30 ·
  • · Replies 35 ·
  • · Replies 20 ·
