How many zeros inside the disk?
by NoDoubts
Tags: disk, inside, zeros
NoDoubts
NoDoubts is offline
#1
Feb3-09, 04:24 AM
P: 20
How many zeros inside the unit disk does the following function have?
f(z) = 3 z^621 - e^z. (in words, three times z to the power 621 minus e^z :)
...argument principle answers this question, but I have a problem evaluating the integral of
f'(z)/f(z).
Phys.Org News Partner Science news on Phys.org
Going nuts? Turkey looks to pistachios to heat new eco-city
Space-tested fluid flow concept advances infectious disease diagnoses
SpaceX launches supplies to space station (Update)
NoDoubts
NoDoubts is offline
#2
Feb3-09, 08:24 PM
P: 20
this is problem 7 from here http://www.math.umass.edu/~hajir/m621/m621hw6.pdf
anyone?
adriank
adriank is offline
#3
Feb3-09, 11:54 PM
P: 534
In general,
[tex]\frac{d}{dz} \ln f(z) = \frac{f'(z)}{f(z)}.[/tex]
Hurkyl
Hurkyl is offline
#4
Feb4-09, 12:17 AM
Emeritus
Sci Advisor
PF Gold
Hurkyl's Avatar
P: 16,101
Quote Quote by NoDoubts View Post
f'(z)/f(z).
Where, exactly, are you having trouble?
NoDoubts
NoDoubts is offline
#5
Feb4-09, 01:12 AM
P: 20
Quote Quote by adriank View Post
In general,
sure. and how does it help?
NoDoubts
NoDoubts is offline
#6
Feb4-09, 01:17 AM
P: 20
Quote Quote by Hurkyl View Post
well, f'(z)/f(z) = (1863*z^620 - e^z}) / (3*z^621 - e^z).
Now, we need to integrate that along the contour C. I've tried to integrate it directly by setting z = e^{theta*i) where 0 < theta <= 2pi , but got stuck.
NoDoubts
NoDoubts is offline
#7
Feb4-09, 09:27 PM
P: 20
anyone?
adriank
adriank is offline
#8
Feb4-09, 09:29 PM
P: 534
In general,
I thought this was hint enough. An antiderivative of [tex]f'(z)/f(z)[/tex] is [tex]\ln f(z) = \ln(3z^{621} - e^z)[/tex].
Am I missing something?
NoDoubts
NoDoubts is offline
#9
Feb4-09, 09:42 PM
P: 20
yes. this is obvious, but how does it answer the question?
what we need to do is, according to argument principle, to calculate an integral on closed countour which is unit circle.
http://en.wikipedia.org/wiki/Argument_principle
adriank
adriank is offline
#10
Feb4-09, 10:34 PM
P: 534
Maybe the argument principle isn't what you should be using?
NoDoubts
NoDoubts is offline
#11
Feb4-09, 11:35 PM
P: 20
do you know how else I can solve this problem?
adriank
adriank is offline
#12
Feb5-09, 12:00 AM
P: 534
I cheated a bit and made some plots, but it looks like 3zn - ez has n zeros in the unit disk, and they look like they're nearish to the zeros of zn - 1. It looks like you have to use the fact that e < 3, since replacing the constant 3 with any number greater than e gives the same number of zeros. If you replace it with e, then you get a zero at z = 1.
NoDoubts
NoDoubts is offline
#13
Feb5-09, 12:09 AM
P: 20
yep. I think I nailed it by Rouche's theorem http://en.wikipedia.org/wiki/Rouch%C3%A9's_theorem
you can majorize the |3zn - ez | by the |7*z^n| on the unit circle |z|=1, then the result follows.
adriank
adriank is offline
#14
Feb5-09, 12:11 AM
P: 534
Looks like that does it. :)
I just started taking a complex analysis course, so unfortunately I'm not very well-informed with regards to that stuff. Glad you solved it, though.
NoDoubts
NoDoubts is offline
#15
Feb5-09, 12:12 AM
P: 20
cheers. now I can move on relieved :)
Hurkyl
Hurkyl is offline
#16
Feb5-09, 12:18 AM
Emeritus
Sci Advisor
PF Gold
Hurkyl's Avatar
P: 16,101
For the record, adriank's earlier hint would have let you directly compute the contour integral... except for the sticky problem that the value of the integrand wraps around the origin (621 times!), and thus must cross a branch cut (621 times), so the straightforward thing wouldn't work.
Of course, if you could prove that it wraps around the origin exactly 621 times, and thus crosses the branch cut 621 times, you could take advantage of the fact you know exactly how big the discontinuity is, and so you still could make a direct calculation of the contour integral.
Register to reply
Related Discussions
Field inside a cavity inside a conductor Introductory Physics Homework 3
Hadamard product and "density" of zeros inside the critical strip.. Linear & Abstract Algebra 0
If ia charge is placed inside a conductor, is the electric field inside zero? Introductory Physics Homework 1
How can I show f(x)=x2-cosx=0 has exactly 2 solutions? Calculus 8
