Deforming Contour of complex function
The discussion centers on obtaining the values of a complex function F(z) along the real axis, given its values along a specific contour defined parametrically by x(t) = cos(t) and y(t) = sin(t) for 0 < t < π. The user employs the Cauchy-Riemann equations to derive the derivatives du/dy and dv/dy from dF/dt, facilitating the integration towards the real axis. While the method shows effectiveness for simple functions like F(z) = z^n, it exhibits instability with more complex functions, leading to error accumulation. The discussion concludes that analytic continuation of F to the entire complex plane is possible, referencing the Kramers-Kronig relations as a valid approach.
  • Understanding of analytic functions in complex analysis
  • Familiarity with the Cauchy-Riemann equations
  • Knowledge of numerical methods for integration
  • Basic concepts of the Kramers-Kronig relations
  • Research analytic continuation techniques in complex analysis
  • Explore numerical integration methods for complex functions
  • Study the Kramers-Kronig relations in detail
  • Investigate stability analysis in numerical methods for differential equations
Mathematicians, physicists, and engineers working with complex analysis, particularly those interested in numerical methods and analytic continuation of complex functions.
yaychemistry
Hi,
First, thank you for reading this.
I've got a complex function, F(z), which is assumed to be analytic, and I know it's values along a contour in the complex plane. Say, for simplicity, that contour is known parametrically as x(t) = cos(t), y(t) = sin(t), 0 < t< pi, thus I know F(x(t) + i*y(t)), and possibly dF/dt.
What I want to do is obtain F(x), that is what is F along the real axis?
What I have done so far is to assume that F obeys the Cauchy-Riemann equations, then if
F(x,y) = u(x,y) + i*v(x,y), I can get du/dy and dv/dy from the information in dF/dt (sets up a nice little matrix problem). Then I can take an integration step towards the real axis to get F at a new contour (e.g. y(t) = 0.99sin(t), x(t) = cos(t)), I can then find dF/dt along this contour (sadly, only through a finite difference formula, or interpolation) and then find du/dy and dv/dy again, take a new step, etc.. until y(t) = 0. It works pretty well for simple test cases, such as, F(z) = z^n, etc. However, it seems to be a little unstable as well when F gets a little more complicated, that is errors tend to build and sometimes the function "explodes" before I get to the real axis.
What I would like to know is if this has been done (in a better way) by someone else, and where I could go about looking. My google searches haven't resulted in much and I don't know my way around the math journals. Any suggestions?
Thanks!
This can be done. If F(z) is analytic and defined over some contour of nonzero length, it should be possible to analytically continue F to the whole complex plane (in a unique way).
The Kramers-Kronig relations demonstrate one example. If F is defined on either the real axis or the imaginary axis, the entire function can be found by doing some integrals.
  • · Replies 19 ·
