Finding an Analog Multiplexer for Accurate Voltage Measurements
  • Thread starter Thread starter BillyBobjoe
    Analog
The discussion focuses on selecting an appropriate analog multiplexer (MUX) for accurate voltage measurements to be fed into a single-input ADC. Participants recommend considering MUX options from manufacturers such as Linear Technology, Maxim, Analog Devices, and National Semiconductor, emphasizing the importance of ON resistance and OFF leakage current specifications. Additionally, the necessity of a sample-and-hold (S/H) circuit is highlighted, which can be integrated with the MUX for optimal performance. Understanding the sampling speed and capacitor values is crucial for selecting the right components.
  • Understanding of analog multiplexers (MUX) and their specifications
  • Knowledge of sample-and-hold (S/H) circuits
  • Familiarity with ADC input requirements and voltage measurement accuracy
  • Basic electronics principles, including ON resistance and OFF leakage current
  • Research specific analog MUX models from Linear Technology and Analog Devices
  • Learn about designing sample-and-hold circuits for ADC applications
  • Investigate the impact of ON resistance on signal integrity in voltage measurements
  • Explore capacitor selection criteria for optimal S/H circuit performance
Electronics engineers, hobbyists designing ADC systems, and anyone involved in accurate voltage measurement and switching applications.
BillyBobjoe
Hi
I need to take in a number of analog voltages onto an ADC but the ADC is a single input. I was thinking of putting the voltages through a MUX and then selecting the input desired to go to the output of the MUX and onto the ADC.
Does anyone know of good analog MUX's/Switches that will allow the desired voltage on the input of the MUX to be selected to go to the output.
My voltage measurements need to be accurate so the input voltage on the MUX must also be seen at the output.
Or is there another way i could go about switching through my voltages into the single input ADC.
Thanks
BillyBobjoe said:
Hi
Thanks
Does your ADC already have a sample-and-hold circuit? If not, you would use the analog mux as the S/H as well as the mux.
Just google analog mux, and you will get lots of good hits. Linear Technology, Maxim, Analog Devices, National Semiconductor all make them. You will pay more for switches with lower ON resistances, so you need to figure out your S/H circuit, including the capacitor value and how fast you want to sample, and how long you want to hold. That will help you choose the ON resistance and OFF leakage current specs to use in picking the device.
  • · Replies 47 ·
  • · Replies 17 ·
  • · Replies 19 ·
