Gravitational vs electromagnetic quantum trajectories
The discussion explores the comparison between quantum trajectories in a hydrogen atom, which is bound by electromagnetic forces, and a hypothetical "atom" composed of two massive neutral particles bound by gravitational forces. Participants examine whether the quantum interpretation of trajectories and the resulting spectra would be similar in both cases, particularly focusing on gravitational radiation versus electromagnetic radiation.
  • Some participants propose that the quantum interpretation of trajectories for a gravitational "atom" might differ from that of a hydrogen atom due to the weaker gravitational force compared to the electromagnetic force.
  • Others argue that if the gravitational force between two neutral particles is set to match the Coulomb force, the system could still be described classically, with no quantum effects observed.
  • A later reply questions whether an isolated hydrogen atom devoid of charge, relying solely on gravity, would still exhibit classical behavior.
  • Participants note the significant difference in the strength of gravitational and electromagnetic forces, suggesting that this disparity affects the nature of the systems being discussed.
  • Some contributions mention potential gravitational wave radiation as a result of the gravitational interactions, while others emphasize that electromagnetic radiation would not occur in this scenario.
  • There are references to experimental evidence related to quantum gravity, with some participants expressing interest in ongoing research and experiments in this area.
Participants do not reach a consensus; multiple competing views remain regarding the nature of quantum trajectories in gravitational versus electromagnetic systems, and whether classical interpretations apply in the proposed scenarios.
Participants highlight limitations in understanding the implications of gravitational interactions at atomic scales, particularly concerning the quantization of orbits and the existence of massive neutral particles. The discussion also reflects on the challenges of comparing gravitational and electromagnetic phenomena.
Loren Booda
Consider a hydrogen atom, with orbitals describing movement of an electron about a proton, together bound by the electromagnetic force. Next consider an equivalent "atom" made up of two massive neutral particles, where the gravitational force at a given separation is the same as the Coulomb force between the above proton and electron, and with a similar center of mass as hydrogen.
Is the quantum interpretation for the trajectories of the latter case essentially the same as that of the hydrogen atom? How does the spectrum appear, and is it of gravitational radiation rather than electromagnetic? Otherwise, is the situation now correspondently classical?
Hint:Consider order of the ratio between strenght of Gravitational force and Coulomb force in nature and estimate the size of the gravitational potential "atom" you are thinking of..
cheers
Remember that the masses of the neutral particles give the same mutual gravitational force over the same distances as the electromagnetic force between electron and proton in the hydrogen atom, and that the relative center of mass is similar in both cases.
Gravitational force between proton and electron is by HUGE order of magnitude smaller than Coulomb force between them over the same distance.
Gravitational force between some two massive neutral particles ,like between two neutrons at Bohr radius separation,is still way way weaker than electromagnetic force between 2 elementar charges at the same separation.
But regardless of that ,you may examine the model (just for the sake of theory) where
2 point ,charge-neutral, stabile masses orbit each other. Set their gravitational force to be the same as Coloumb force between 2 elementar charges.Firstly you will notice there are some effects doing this ,like radious change due to changed mass etc.
But even that isn't important.Now,I guess that your primary interest would be to know 1.wether trajectories are subjected to some degree to quantum interpretation of electron trajectories in hydrogen atom?
and
2.if there is EM radiation?
Answer1:No.The system is still described classicaly very well.
Answer2:Potentatialy just weak gravity wave radiation can occur.Gradually, the system looses energy.
There's significant difference between classical EM fields, quantum EM fields and associated QM fluctuations of EM field that occur on stage of theoreticaly flat -unperturbed spacetime ,and ,on the other side, "fluctuations" of the stage (spacetime) itself.The thing we don't fully understand yet.
Even in classical physics clear example ,quite fundamental difference,is fact that in classical physics nothing can stop graviational wave while EM waves can be stopped by appropriate conductive shield.
regards
Let's assume that the neutral particle situation is classical. What if an isolated hydrogen atom is devoid of charge, having only gravity to cohere the electron and the proton - is that now classical?
Beautiful! Why hasn't this more renown? The data requires more scrutiny, refinement, and replication, though. I might extrapolate the given experiment to a neutron star's radial gravitational resonances, perhaps measurable in a pulsar's E-M spectrum at 1.2 x 106m for the first ground transition. Thank you for gracing us with your presence, Hurkyl.
I havn't really read anything you've said, but i'll just say this
gravity is the weakest force, think about it, a small magnet can pick up a piece of metal against the gravity created by the whole planet.
Hurkyl said:
You may find this interesting
http://www.users.csbsju.edu/~frioux/neutron/neutron.htm
to my knowledge, this sort of thing is the only experimental evidence existing dealing with quantum gravity.
Is anyone else trying to duplicate their experiment? The data looks convincing to me.
Do you know how the neutron detector might work?
Thanks
The "Booda experiment"
Visualize two fields of hydrogen atoms, one whose spin axes oscillate by a strong magnetic field between poles parallel and antiparallel to the Earth's gravitational field, and the others' spin axes oscillate by a magnetic field of equal magnitude between poles perpendicular and antiperpendicular to the Earth's gravitational field. The difference between the frequency of precessing electrons radiating in the two situations may be evidence of quantum gravity.
If masses are comparable with m*masses of proton and electron than no.if just gravity holds them togather in atomic size orbit (in classicall physics generally elliptical) than rotational energy is low ,slow velocity-->long DeBroglie wavelength.
However,remember what I told you about simulating same magnitudes Coulomb force of hydrogen atom at same atom radius sizes by gravity interaction between 2 particles. Take the same ratio Mp/Me ,assume circular orbit, and calculate rest mass of Mp in eV.Now the problem of quantizating the orbit decreases:you will see that quantum problem shifts to HE "nuclus" question wether or not neutral particle of such a huge rest mass can exist.Which would open road to difficult questions such as relation between quantum gravity and strong nuclear force etc,etc.
regards
  • · Replies 23 ·
