How can I add an icon to my MinGW compiled program for Windows?
  • Thread starter Thread starter Coin
The discussion revolves around how to add an icon to a Windows executable file compiled with MinGW, particularly from a macOS environment. Participants explore methods to associate or embed an icon in the .exe file without direct access to Windows functionalities.
  • One participant describes their setup of compiling Windows executables on macOS using MinGW and seeks guidance on embedding an icon in the .exe file.
  • Another participant suggests using Windows API functions like LoadIcon, referencing a programming book for further reading.
  • A participant clarifies that they want a static icon for the application, not a runtime change, and expresses confusion about how to achieve this without Windows access.
  • One participant shares their experience using Code::Blocks and MinGW on Windows, mentioning that including an icon file as a resource is straightforward.
  • A later reply points to a specific tutorial as a solution for command line tools, indicating that they successfully implemented it.
  • Another participant references an alternative tutorial that they found easy to follow for adding icons.
Participants present various methods and resources for adding an icon, but there is no consensus on a single approach. Multiple suggestions and tutorials are provided, reflecting differing experiences and preferences.
Some participants mention limitations due to not being on a Windows system, which may affect their ability to test or implement certain solutions directly. There is also a reliance on external resources and tutorials, which may vary in clarity and applicability.
Coin
Okay, here's one.
- I'm developing a program for macintosh+windows.
- But, I myself am on a macintosh.
- So, I installed MinGW on my mac. Now, I can compile Windows .exes sitting here on my macintosh. (This part already works.)
- But I can't figure out: How do I give my program an icon?
I have here a .ico I made, but I don't know how to associate it with or embed it into my Windows .exe. I don't really know how Windows icons work. Is there a way to do this using mingw or any open source tool I can run on my mac? (I.E. what I'm trying to do somehow prep the exe is so that when I zip it up and send it over to a windows machine, the windows user will see the icon immediately.)
Technology news on Phys.org
It is a GUI app or Console app?
You should try some windows API function such as LoadIcon. You should read books such as <<windows programming>> by Charles Petzold.
It is a normal type gui app.
I'm not sure what you mean about the API? I don't mean I want to change the icon at runtime, I mean like I want some file to be the program's icon even before it launches and I can't do the normal thing of right click->properties because I'm not actually on windows myself.
Oh, I'm using code::blocks and Mingw under windows, so, with application wizard, it is easy to generate a gui application.
You can use include an icon file as it's resource file.
That all I know.
OK. Thanks for the help.
It turns out that the correct answer if you're limited to the command line tools is to http://www.cyrocom.co.uk/tutorials/cpp/icon.html . I got it working using this.
Hi. Actually the http://blog.stranadurakov.com/2009/04/27/icon-and-version-information-resource-file/" is pretty easy.
  • · Replies 25 ·
  • · Replies 29 ·
  • · Replies 23 ·
