Derivation of Length Contraction (special relativity)
The discussion focuses on the derivation of length contraction in special relativity, specifically using a moving light clock as a model. The key equation derived is t1 + t1(2) = gamma*time = 2 * Moving Length / c*(1 - u²/c²), leading to the expression for Moving Length as (c*(gamma*time))*(1 - u²/c²). The final goal is to demonstrate that the Moving Length equals "Normal" length divided by gamma. Participants emphasize the importance of correctly identifying the frame of reference for measuring the wall separation.
  • Understanding of special relativity concepts, particularly time dilation and length contraction.
  • Familiarity with the Lorentz factor (gamma) and its mathematical implications.
  • Basic knowledge of light clock mechanics and how they illustrate relativistic effects.
  • Proficiency in algebraic manipulation of equations involving square roots and fractions.
  • Study the derivation of the Lorentz transformation equations in detail.
  • Learn about the implications of time dilation and length contraction in various frames of reference.
  • Explore practical examples of length contraction in high-speed scenarios, such as particle physics.
  • Investigate the relationship between relativistic mass and energy using E=mc².
Students of physics, educators teaching special relativity, and anyone interested in the mathematical foundations of relativistic effects.
Chewy0087
Show the derivation for legnth contraction, given that from the example given;
The example shows a moving light clock - two walls which are moving in a direction at speed u and a beam of light from wall A to wall B then back to A and so forth.
From Ao (starting point) to B1 (distance moved after the beam has got there)
=t1 = "Moving" legnth / c - u
And from B1 - A2
t1 (2) = "Moving" Length / c + u
t subscript 1 = 2L / c * sqroot (1 - u²/c²)
Basically the time dilation equation is given (and i managed to work out in an earlier question)
Well I added up t1 and t1 (2), to get the time taken by the light to do one back and forth getting;
t1 + t1(2) = gamma*time = 2 * Moving Length / c*(1- u²/c²)
Making Moving length the subject;
Moving Length = (c*(gamma*time))*(1-u²/c²)
Put gamma into the equation;
Moving Length = (c/2)*(1-u²/c²)*2L/(c*sqrt(1-u²/c²))
And from here I'm totally stuck, I do know that the final answer is "Normal" length / gamma but really stuck taking the final steps... :/
Any help would be appreciated
You're missing a factor of 2 here, but you seem to have got it right on the next step.
By "moving length", do you mean the wall separation measured in the lab frame or the moving (light clock) frame? Think about this.
As far as the math goes, you're nearly done. It's just a matter of canceling out terms from the numerator and denominator.
  • · Replies 32 ·
  • · Replies 54 ·
  • · Replies 44 ·
