What Controller Configuration Works Best for Cascade Buck Converters?
The discussion revolves around the design of cascade buck converters, specifically focusing on the choice of controller configuration. Participants explore the implications of using independent versus dependent controllers for the converters.
  • One participant expresses confusion about whether to use independent controllers for each converter or a single controller for all converters.
  • Another participant suggests using two separate controllers but emphasizes the need for synchronization to avoid stability issues due to independent clock rates.
  • It is noted that some controllers have sync-in and sync-out leads, which may facilitate synchronization.
  • A participant indicates a preference for using separate controllers while synchronizing them, and seeks references for further reading on cascade converters, mentioning the complexity of their controllers.
Participants generally agree on the potential benefits of using separate controllers with synchronization, but there is no consensus on the best approach, as the initial question remains unresolved.
The discussion highlights the complexity of cascade converters and the challenges in finding references, indicating a limitation in available literature on the topic.
i_m_man
i want to design cascade buck converter,but I'm kinda confuse about the controller that i'll use for the converter...there are 2 options, i make the controller independent from 1 converter to another, or i just make the controller dependent, it means that i have only 1 controller for all converter..any suggestion for that??
I'd be inclined to use 2 separate controllers, but synchronize them. If they have independent clock rates, there could be some stability issues. Alternately, just use good filtering between them to keep the ripple low going into the 2nd stage.
Some controllers come equipped with sync-in and sync-out leads.
thanx for the reply...i think i'll go with separate controllers but synchronize them..
does anyone has reference that i could read about cascade converters..cause usually people don't use cascade converter since its controllers that a little bit complex,so it's difficult to find the reference..
  • · Replies 17 ·
