Multiple choice questions about SHM
Reflection applies to both transverse and longitudinal waves, confirming option c as correct. Increasing the mass of the bob on a spring will increase the period of vibrations, as indicated by the formula T=2π√(m/k). Releasing a spring from progressively larger displacements will also increase the maximum velocity of the bob, based on the relationship vmax=2π*displacement/T. The discussion emphasizes the nature of light as a transverse wave and sound as a longitudinal wave. Overall, the answers provided for the homework questions are affirmed as correct.
phys1618
1.Reflection goes with
a. longitudnal wave
b.trasnsverse wave
c. both
d.neither
2.
if mass of teh bob on a springs are increased, howe whould that affet the period of the vibrations?
3. if a spring is released fr. progressively larger displacments, how owould this affect eh e max. velocity of teh bob.
1. transverse, because reflection refers to light right?
2. increase becase T=2pi(sq.root(m/k))
3.increase because vmax=2pi*displacement/(T)
For the answer to number 1) What kind of wave is light? Does light reflect? What kind of wave is sound? Ever hear an echo? (Check Wikipedia if you don't know the answers to my questions)
Your answer to 2) and 3) are correct.
yes it does. light is transverse and sounds is longitudinal...so i guess the answer is c. both.
Yup!
thank you.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
