| Thread Closed |
Surface Waves of an Oil Ocean |
Share Thread | Thread Tools |
| Feb8-09, 09:47 PM | #1 |
I'm interested in the physical behavior of surface waves in an oil-based ocean.
Suppose, if you will, an ocean created of crude oil. How would its waves behave in relation to our own oceans' waves? I think oil waves would be slower and lower in height, but how much slower and lower I don't know. I'm sure there are other characteristics to consider as well. Care to speculate? |
| Feb8-09, 09:53 PM | #2 |
(1) Get a house fan
(2) Get a cat liter box (3) Fill said box with water. Turn on fan. Take Picture (4) Empty box, and refill with motor oil. Turn on fan, take picture. (5) Using a funnel, put motor oil back into the container for use in your car when in need of top off. (6) Post pictures here. |
| Feb8-09, 10:05 PM | #3 |
...but I'm a theorist...
ok I thought of doing an experiment myself... i guess i have to now |
| Feb8-09, 10:25 PM | #4 |
Slightly off topic anecdote:
When Ben Franklin was a diplomat to France, once he was walking close to a body of water with two Frenchmen on a windy day. Always having a keen sense of humor and an interest in science he told the Frenchmen to step back, he was going to calm the waters. Franklin was carrying a hollow cane he had filled with oil beforehand. He unstoppered the cane and waved it over the water and behold, the waters were calmed. The Frenchmen were duly impressed. |
| Feb8-09, 10:31 PM | #5 |
| Feb8-09, 10:57 PM | #6 |
Mentor
| Feb8-09, 11:14 PM | #7 |
Google might provide some quantitative data. |
| Feb8-09, 11:42 PM | #8 |
Surface roughness is a complex phenomenon that depends on many things, including the surface under the water. The water has ripples and waves in different parts of the lake due to different ground textures. You could also test this in your litter box. Fill it with water and turn on the fan. Then fill the bottom with gravel and repeat. You will get a different wave pattern. |
| Feb9-09, 08:48 AM | #9 |
The whole intention of carrying the oil with him was so he could perform his own experiments whenever the opportunity arose. The honour of Dutch seamen: Benjamin Franklin’s theory of oil on troubled waters and its epistemological aftermath Edit: skeptic2's anecdote wasn't off topic, at all. |
| Feb9-09, 09:02 AM | #10 |
I am done all undergrad physics courses but never saw anything about surface waves. |
| Feb9-09, 10:02 AM | #11 |
Thanks BobG. I had remembered it as happening in France. I guess I was mistaken.
| Feb9-09, 10:06 AM | #12 |
| Feb9-09, 10:39 AM | #13 |
Recognitions:
A quick google shows that an ocean wave travels at:
[tex] v = \sqrt{ \frac{g\lambda}{2\pi} \tanh\left(\frac{2\pi d}{\lambda}\right)} [/tex] Where v is the velocity, [tex]\lambda[/tex] is the wavelength of the traveling wave, d is the water depth, and g is gravity. It seems independent of fluid density. This is counter-intuitive to my initial thinking, which relates to speed of propagating sound waves. The speed of sound can be written as: [tex] c = \sqrt{\gamma \frac{p}{\rho}}[/tex] Where p is pressure and [tex]\rho[/tex] is the fluid density. An increase in fluid density in sound waves decreases the speed of sound. However, it seems as though from a few sources that the speed is a function of wavelength only. http://www.owrc.com/waves/waves.html |
| Feb9-09, 03:51 PM | #14 |
Wavelength never determines speed. It's always better to think of any wave in terms of its frequency rather than its wavelength... because the frequency (usually) doesn't change. I'll state "usually" because of certain things like harmonic generation, etc. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Surface Waves of an Oil Ocean
| Standing waves in surface vibrations in rods? | Classical Physics | 22 | ||
| wave scattering/dispersion? (body waves and surface waves) | Advanced Physics Homework | 0 | ||
| [SOLVED] How can a surface be polished for some waves and not others? | Introductory Physics Homework | 2 | ||
| Using Euler's equations to model ocean waves | Classical Physics | 0 | ||
| the surface waves in plasma | General Physics | 0 | ||
