Help me - A function satisfies the differential equation
The discussion revolves around a differential equation of the form dy/dt = y^4 - 6y^3 + 5y^2. Participants are exploring the characteristics of the function defined by this equation, including constant solutions and intervals of increase and decrease.
  • Mixed
  • Participants are attempting to identify constant solutions and the conditions under which the function is increasing or decreasing. There is some confusion regarding the correct interpretation of the differential equation and its variables.
The discussion is ongoing, with participants providing various interpretations and clarifications. Some guidance has been offered regarding the nature of constant solutions and the algebraic requirements of the problem, though there is no explicit consensus on the correct approach yet.
There appears to be some misunderstanding about the formulation of the differential equation, with one participant suggesting an incorrect version. The problem emphasizes that solving the differential equation is not necessary for the tasks at hand, which focus on algebraic equations and inequalities.
butbi9x
A function satisfies the differential equation:
[tex]\frac{dy}{dt}= y^{4}-6y^{3}+5y^{2}[/tex]
a. What are the constant solutions of the equation?
b. For what values of y is y increasing?
c. For what values of y is y decreasing?
What are your thoughts on the problem? What have you attempted thus far?
dy/dt=y'(t), its ur function or, simple, y(t), after integration.
Do you understand that this does NOT require that you actually solve the differential equation? It only requires that you solve an algebraic equation and two inequalities.
i think it should be
y'(t)=t^4-6t^3+5t^2
where
y'(t)=dy/dt
now integrate it
we have
y(t)=...
constant solution mean y'(t)=0.
mean no variation w.r.t "t".
for what value of "t" is y increasing...
and for what value of "t" is y decreasing.
i think now u can handle it easily
y'(t)=t^4-6t^3+5t^2
No, that's completely wrong. The DE equation is dy/dt = y4 - 6y3 + 5y2. If if were as you have it, this would be a different problem completely.
masqau said:
where
y'(t)=dy/dt
now integrate it
we have
y(t)=...
  • · Replies 27 ·
