Prove this is a Real Vector Space
The problem involves proving that a set of real functions defined by the differential equation d²y/dx² + 9y = 0 forms a 2-dimensional real vector space. The discussion includes verifying vector space axioms and exploring the implications of the functions being solutions to the differential equation.
  • Participants discuss the need to verify vector space axioms such as closure under addition and scalar multiplication, as well as the implications of functions being solutions to the differential equation.
Some participants have provided guidance on the necessary steps to demonstrate that the set of functions satisfies the vector space properties, while others express confusion about the differential equation and its implications for the functions involved.
There is a noted lack of familiarity with differential equations among some participants, which affects their understanding of the problem setup and the necessary mathematical tools to approach the proof.
fk378
Let V be the real functions y=f(x) satisfying d^2(y)/(dx^2) + 9y=0.
a. Prove that V is a 2-dimensional real vector space.
b. In V define (y,z) = integral (from 0 to pi) yz dx. Find an orthonormal basis in V.
part A:
I integrated and got that f(x)= (-3/2)y^3 + Cy, C is a real number.
It seems like I need to use dot product here. I don't know how, though.
part B:
Completely lost.
First off, f(x) should be a function of x.
Second, you made a mistake in solving your DE: the solutions to y'' + 9y = 0 are not what you show.
What do you know about the characteristic equation of a linear DE?
Oh, I never took a DE class. All I did was integrate it twice, and I didn't even realize it wasn't a function of x. What should I do?
OK. You don't need to know how to solve the equation in order to verify that the set of all solutions to it is a vector space.
You know that you have to verify a set of axioms involving addition and scalar multiplication, right?
Yes..
Under addition we must show it is well-defined and
1. Associativity
2. commutativity
3. zero element
4. inverses
5. closed
Under multiplication we need to show well-definedness and
1. L and R distribution
2. associativity
3. id (unit)
4. zero element
5. closed
do I have it covered here?
Yes, those are the axioms that you have to verify.
Let f, g, and h be elements of V. (What does that imply in regard to your DE?. IOW, what exactly does it mean for a function to be an element of V?)
Let a and b be real numbers.
To pick a couple, #4 in the addition group and #4 in the scalar multiplication group:
If g is in V, is there another element h in V so that g + h = 0?
If g and h are in V, is g + h in V?
The point was that you wrote f(x)= (-3/2)y^3 + Cy. "y" is not "x"! If you had had d^2y/dx^2= a function of x, then you could integrate twice but you cannot integrate an expression in "y" with respect to x when you don't know y as a function of x.
Presumably you already know that addition of functions is associative and commutative, that f(x)= 0 for all x is the additive identity, etc and don't need to prove that here. All you really need to show is that if f(x) and g(x) are functions satisfying d^2f/dx^2+ 9f= 0 and d^2g/dx^2+ 9g= 0 then any linear combination of them, af(x)+ bg(x) for a and b any numbers, also satisfies that.
Well how do I use the second derivative in helping me prove that V satisfies all the axioms?
By using the theorems of differentiability. If f and g are differentiable functions, then so is f + g, and (f+g)' = f' + g'. Also, if a is a constant, then af is differentiable, and (af)' = af'. These ideas can be extended to the next higher derivative.
  • · Replies 18 ·
  • · Replies 58 ·
  • · Replies 17 ·
