Parametric Equation Speed
by keemosabi
Tags: equation, parametric, speed
keemosabi
keemosabi is offline
#1
Feb12-09, 10:09 PM
P: 109
Can someone please tell me how to get the average speed of a particle moving along a path represented by parametric equations? Is it [latex]\frac{1}{b-a}\int_{a}^{b}\sqrt{\frac{dx }{d t}^2 + \frac{d y}{d t}^2}[/latex]
Isn't this the arc length formula?
Phys.Org News Partner Science news on Phys.org
Simplicity is key to co-operative robots
Chemical vapor deposition used to grow atomic layer materials on top of each other
Earliest ancestor of land herbivores discovered
w3390
w3390 is offline
#2
Feb12-09, 10:13 PM
P: 344
This is the arc length formula. The average value formula is Favg=(1/b-a)INT[f(x)dx]. It seems you combined two formulas.
keemosabi
#3
Feb12-09, 10:38 PM
P: 109
Quote Quote by w3390 View Post
But if I wanted the speed of a particle moving with a parametric graph, woldn't everything under the radical be my speed function?
w3390
w3390 is offline
#4
Feb12-09, 10:40 PM
P: 344
Actually, you may be right. I think that might actually work.
Dick
Dick is offline
#5
Feb13-09, 12:27 AM
Sci Advisor
HW Helper
Thanks
P: 25,165
No, no, no. The average speed is displacement over time. It has nothing to do with arc length. It's sqrt((x(b)-x(a))^2+(y(b)-y(a))^2)/(b-a) where a is the intiial time and b is the final time. Right?
keemosabi
#6
Feb13-09, 08:11 AM
P: 109
Quote Quote by Dick View Post
Couldn't you also do the average value of the absolute value of the velocity graph?
Dick
Dick is offline
#7
Feb13-09, 08:53 AM
Sci Advisor
HW Helper
Thanks
P: 25,165
Quote Quote by keemosabi View Post
Yes, you could. In which case that would be correct. Distance travelled/time could also be considered an average speed. I was only thinking of the displacement/time definition.
keemosabi
#8
Feb13-09, 10:02 AM
P: 109
Alirght, thank you for the help.
Also, is there any way to determine if a particle traveling on a parametric path is increasing in speed? I know I can determine if the x and y are accelerating, but I can I determine if the particle itself is increasing?
What if it was accelearating in the x direction but decelerating in the y? Would the particle's speed be increasing or decreasing?
Dick
Dick is offline
#9
Feb13-09, 10:11 AM
Sci Advisor
HW Helper
Thanks
P: 25,165
The 'speed' is sqrt((dx/dt)^2+(dy/dt)^2), isn't it? Just look at whether that quantity is increasing or decreasing.
Register to reply
Related Discussions
parametric equation Calculus & Beyond Homework 2
Parametric Equation Calculus & Beyond Homework 1
Parametric equation Calculus & Beyond Homework 5
Parametric equation Advanced Physics Homework 5
parametric equation Calculus 8
