Thread Closed
Total angular momentum of hands of Big Ben
Share Thread Thread Tools
Feb13-09, 04:19 PM   #1
Hello I just can't seem to get this problem right
The hour and minute hands of Big Ben in London are 2.6 m and 4.58 m long and have masses of 68.6 kg and 97 kg respectively. Calculate the total angular momentum of the minute and hour hand about the center point. Treat the hand as long, thin rod. Treat “into the clock” as the positive direction. Answer in units of kg · m2/s.
2. Relevant equations
[tex]\omega = \frac{ 2\pi }{T}[/tex]
[tex]I = \frac{1}{3} M R^2 [/tex]
[tex]I = \frac{1}{12} M R^2 [/tex]?
[tex]L = I \omega [/tex]
3. The attempt at a solution
Mmin= 68.6
Mhour = 97
lmin = 2.6
lhour = 4.58
[tex]\omega min = \frac{2\pi}{3600}[/tex]
[tex]\omega hour = \frac{2\pi}{86400}[/tex]
[tex]Imin = \frac{1}{3} Mmin lmin^2 [/tex] = 154.579
[tex]Ihour = \frac{1}{3} Mhour lhour^2 [/tex] = 678.237
[tex]Lmin = Imin \omega min[/tex] = 0.269791
[tex]Lhour = Ihour \omega hour[/tex] = 0.0493228
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Feb14-09, 09:01 AM   #2
Recognitions:
Homework Helper Homework Help
Your calculation looks all right, so probably you've just made a little mistake somewhere.
Are you sure you aren't switching the minute and hour hands somewhere halfway? The hour hand is 2.6 m and 68.6 kg and the minute hand is 4.58 m and 97 kg. Are you using that consistently?
You are giving two formulas for the moment of inertia, with 1/3 and 1/12 in front. Can you explain the difference?
Also, don't forget your units, especially in the final answer (what is the unit of angular momentum?)
Feb17-09, 06:34 AM   #3
Thanks I found out where I was wrong now, I was switching the mass numbers of minutes and hour hands.
Thread Closed
Tags
angular momentum, big ben, inertia
Thread Tools
Similar Threads for: Total angular momentum of hands of Big Ben
Thread Forum Replies
total angular momentum Advanced Physics Homework 6
Total Angular Momentum of a dumbbell Introductory Physics Homework 2
Total angular momentum Q Introductory Physics Homework 1
Total Angular Momentum Introductory Physics Homework 1
eigenvalues of total angular momentum Quantum Physics 5
