Thread Closed
Rectified Voltage Waveform
Share Thread Thread Tools
Feb13-09, 06:52 PM   #1
A sinusoidal voltage waveform is rectified so that it becomes a half-wave waveform (i.e. the bottom half has been "chopped off"). Determine:
i) The average p.d.
ii) The RMS p.d.
iii) The heat dissipated in a 200ohm resistor in 100s
2. Relevant equations
[latex]P_{avg} = \frac{(V_{rms})^2}{R}[/latex]
3. The attempt at a solution
I'm not sure, but I would guess that the average p.d. is the line that cuts the rectified waveform in such a way that the area above and below is the same. I have a vague recollection about it being [latex]\frac{2}{\pi}[/latex] times the peak voltage.
I am also quite uncertain about the RMS, how would the voltage being zero half the time affect this value? I'm guessing it will no longer be [latex]\frac{\sqrt2}{2} V_{peak}[/latex].
Please could anyone give me some clues on how to work out the RMS and average values?
EDIT:Oops sorry I did not mean to post the same thread twice...just ignore the other one!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Feb13-09, 08:39 PM   #2
Recognitions:
Homework Helper Homework Help
I don't know of any formula for the half-wave signal. I rather think you will have to find out what "root mean square" means and work it out from the definition - no doubt you will be integrating over a full wavelength (the V = zero part will be easy!).
The average potential will be the same sort of thing, the area divided by the time.
Thread Closed
Thread Tools
Similar Threads for: Rectified Voltage Waveform
Thread Forum Replies
Integral of full-wave rectified sinewave, find equivalent sine waveform Calculus & Beyond Homework 0
RMS of Fullwave rectified sine wave. Calculus & Beyond Homework 3
Multimeter measuring full-wave rectified DC current? Introductory Physics Homework 7
Smoothing a rectified a.c current Classical Physics 3
