Synthesis of oxalate complexes, post lab question
  • Thread starter Thread starter natash
    Lab Synthesis
The discussion focuses on the synthesis of Iron(III) Oxalates, specifically the challenge of calculating the theoretical yield from the lab procedure. The key steps involve preparing solutions of ferrous ammonium sulfate, oxalic acid, and potassium oxalate, followed by a series of heating and washing processes to isolate the final product. The participant has determined an actual yield of 2.835g but is struggling to derive the balanced equation necessary for calculating the theoretical yield. The formula for the complex being prepared is also questioned.
  • Understanding of stoichiometry and molar conversions
  • Familiarity with the synthesis of coordination compounds
  • Knowledge of chemical equations and balancing techniques
  • Experience with laboratory techniques such as filtration and crystallization
  • Research the balanced chemical equation for the synthesis of Iron(III) Oxalates
  • Learn about stoichiometric calculations for determining theoretical yield
  • Study the properties and reactions of oxalate complexes
  • Explore laboratory techniques for isolating and purifying chemical compounds
Chemistry students, laboratory technicians, and researchers involved in inorganic synthesis and coordination chemistry will benefit from this discussion.
natash
Okay I'm having trouble with my post lab question. This lab is on the synthesis of Iron(III) Oxalates. I have to figure out the theoretical yield, but i can't seem to even find a balanced equation. I've gone over this a million times but can't seem to figure it out.
here is the procedure
1. a) prepare 10 g of ferrous ammonium sulfate dissolved in 30mL of water containing 2 drops of 6M H2SO4 b) 6g of oxalic acid in 50 mL of water c) 6.6 g of K2C2O4H2O in 18 mL of water d) 1.7 g oxalic acid in 15 mL of water
2. carry out the following preparation in a 250 mL beaker. To the ferrous ammonium sufate solution add, with stirring, the solution of 6 g oxalic acid in water. A yellow precipitate of iron(II) oxalate forms quickly. Carefully heat the mixture to near boiling, stirring constantly to avoid bumping. Allow the precipitate to settle, decant and discard the supernatant liquid.
3. wash the precipitate three times by adding 30mL of hot water, stirring and decanting the liquid. Filtering is not necessary at this stage of the synthesis.
4. add the 6.6g potassium oxalate/18mL water solution to the wet iron (II) oxalate precipitate and heat the mixture to about 50 C. Slowly add 17ml of 6% H2O2 while stirring and maintaining a temperature of about 50 C for at least 15 mins or until al the unconverted iron (II) oxalate is converted.
5. heat the mixture to boiling and slowly add the 1.7g oxalic acid in 15mL water solution ; maintain the temperature near boiling for 10 mins. filter away any precipitate before adding ethanol. Add 20 mL 95% ethanol t the filtrate. cover the beaker with a watchglass, wrap in aluminum foil and place the beaker in your locker until next week.
6.after 1 week, filter the green product crystals with a buchner funnel, and wash twice with a few mL of 50% aqueous ethanol, then with a few mL of 95% ethanol. Continue to aspirate the crystals on the filter for 30 mins. to air dry your samples. Cover with aluminum foil during drying to prevent photocomposition. when dry, isolate and weigh your sample to determine the % yield.
%yield=actual yield/theoretical yeild *100 for actual yield i got 2.835g
I'm not sure do I start out with 10g of ferrous ammonium sulfate and convert to moles to find theoretical yield...im so confused
What is formula of the complex you were preparing?
  • · Replies 19 ·
11K
