Calculating Maximum Flow Rate for Vacuum Chamber
The discussion revolves around calculating the maximum flow rate for a vacuum chamber, specifically focusing on the conditions of gauge pressure, dimensions of the gap, and the implications of these factors on flow rate calculations. The scope includes technical reasoning and conceptual clarification regarding vacuum pressure measurements.
  • One participant states the gauge pressure inside the vacuum chamber is about 250 mmHg and asks for the maximum flow rate per meter, given a gap of 2 mm width and a thickness between 1 - 10 mm.
  • Another participant questions the nature of gauge pressure in a vacuum chamber, suggesting it should be negative and requests conversion to Pa or Psi, along with a sketch for clarity.
  • A third participant acknowledges the negative gauge pressure and provides a rough sketch of the chamber in response to the previous comment.
  • One participant references an external resource on orifice plates, suggesting it may provide useful insights for the flow rate calculation.
  • Another participant expresses skepticism about the pressure value of 75 MPa, noting that it does not seem like a vacuum and suggests that mmHg is more commonly referred to as Torr. They inquire if the flow rate is being calculated based on a 250 Torr pressure difference across the specified slot.
Participants express differing views on the nature of gauge pressure in vacuum chambers, with some questioning the provided pressure values and others clarifying the context. The discussion remains unresolved regarding the calculation of maximum flow rate and the implications of the pressure measurements.
There are limitations regarding the assumptions made about pressure definitions and the specific conditions under which the flow rate is to be calculated. The discussion does not resolve the mathematical steps necessary for determining the flow rate.
bigdream
I'm now making a vacuum chamber.
The gauge pressure inside the vacuum chamber is about 250 mmHg.
There will be some gap on the operating surface, about 2 mm width.
The thickness of the gap is between 1 - 10 mm.
What is the maximum flow rate per meter for the vacuum chamber?
ummm, shouldn't a vacuum chamber have a negative gauge pressure (and could you put it into Pa or Psi)? also, a sketch would help greatly.
Thanks for the comment. The vacuum chamber have a negative gauge pressure. The attachment is the rough sketch of the chamber.
75 Mpa does not seem like vacuum to me, also it is more common to refer to mmHg by Torr.
Are you trying to find the flow rate based on 250 Torr pressure difference acros a slot of 2 mm width?
  • · Replies 28 ·
9K
