Laser rate equation(ODE) simulation problem
  • Context: Graduate
  • Thread starter Thread starter oronno
    Laser Rate Simulation
The discussion revolves around simulating the laser rate equations using MATLAB. Participants share code snippets, troubleshoot issues, and explore the physical implications of the equations involved. The conversation includes technical explanations, debugging assistance, and variations in the formulation of the equations.
  • Homework-related
  • One participant shares a MATLAB code for simulating the laser rate equations but encounters issues with the code execution.
  • Another participant questions the physical meaning of the equations and suggests that the initial conditions may lead to numerical instability.
  • Some participants discuss the importance of dimensionless variables and their potential impact on the simulation.
  • A participant provides an alternative formulation of the rate equations, suggesting modifications to improve the simulation results.
  • There are mentions of specific parameters and their roles in the equations, such as transparency current and carrier lifetime.
  • One participant expresses gratitude for the shared code and seeks references for the equations used in the discussion.
  • Another participant points out a potential inconsistency regarding the definition of the spontaneous emission coefficient.
Participants express varying opinions on the effectiveness of the provided code and the formulation of the equations. There is no consensus on the best approach to resolve the issues encountered, and multiple competing views on the significance of dimensionless variables and initial conditions remain present.
Some participants mention the need for careful selection of initial conditions and parameters to ensure convergence in the numerical solution. The discussion also highlights the complexity of the equations and the potential for different formulations to yield different results.
Individuals interested in laser physics, MATLAB programming, and numerical simulations of differential equations may find this discussion beneficial.
oronno
hello...
Can anyone tell me how can I simulate the laser rate equation with matlab? i already wrote a code whics is as follows,
%have to write one editor
function dy=rate_equation(t,y)
dy = zeros(2,1);
I =50e-3;
%for t=1:10;
q =1.602e-19;
v =9e-11;
eps =3.4e-17;
N0 =1.8e-18;
tn =3e-9;
g0 =3e-6;
lamda=0.44;
bita=4e-4;
tp=1e-12;
dy(1)=(I/(q*v))-((g0*(y(1)-N0)*y(2))/(1+eps*y(2)))-(y(1)/tn);
dy(2)=(lamda*g0*(y(1)-N0)*y(2))/(1+eps*y(2))-(y(2)/tp)-((lamda*bita*y(2))/tn);
end
%have to write other editor
%step size=0.01;
clc
tspan=[0,10];
y0=[0,1];
[T,Y]= ode45(@try1,tspan,y0);
plot(T,Y(:,1),'-',T,Y(:,2),'.');
title('plot of carrier and photon densities');
xlabel('time');
ylabel('densities');
So what really is the problem? You have written the code. Have you run it?
bro...i wrote the code and tried to run it. but every time i try to debug it...the MATLAB gets busy and no result comes out. seems there's something wrong with the code. so, i need someone to help me out
Actually I don't have slightest idea the physical meaning of your equation and I'm also quite new to Matlab. Only able to write small script file.
From your equations, it looks as if you have three dependent variables N, S, and I. Do you assume I(t) to be constant here?
In your script file you use the anonymous function @try1 whereas your function m-file is rate_equation.
Hopefully you have type your equations commands correctly.
Is there any chance you dimensionless all your variables?
thanx bro for yoyr reply. here S and N are two dependent variables. they are dependent on each other. and I here is constant. or we can vary I in any range ( like 50-70 mA , or 20-50 mA). and you are right on the @try1. it should be @rate equation. actually I tried with different different m files and mistakenly I pested @tri1 here.
and I didnt understand what did you mean by your last line (dimentionless variables).
thanx for your concern and I am waiting for your reply.
May be dimensionless the variables are not important in this problem. Dimensionless doesn't make the problem simplier, it only us to control what values to generate. I think.
I used to work on diffusion problem before, solving pde for material concentration c(x,t). We didn't solve the equation numerically but analytically. A lot of linearization has to been done.
We knew, such as, the maximun length material could diffused x0, etc.
Rather than work with the variable x, we used the variable [tex]y=\frac{x}{x_0}[/tex] which is dimensionless. We then generate only the value 0<y<1. Similarly were done to other quantities t, c etc.
In your program, what make you chose t=[0 10] ? May be your intuition.
Your equations are nonlinear. Value need to be careful chosen so that the solution converges. If you think you have done everything correct but still don't get any result, probably the subroutine ode45 is not suitable for solving your problem. We don't know the algorithm behind ode45. Try other subroutine.
Hi!
I'm working successfully with rate equations for lasers with matlab.
Your code, oronno, is ok. The ode45 routine of matlab, which uses Runge-Kutta method, is good for our kind of non-linear differential equations. So, is it ok? No, I think there's a kind of numerical instability of algorithm when you choose wrongs initial conditions(a good idea is 0 for carriers and 0 for photons). Then, maybe there's a problem that regard your formulation of the rate equations. I tried one like your but i had no answers from MATLAB like you.
So, i searched for another formulation and ...WOW .
I append the current version,that's a little bit redundant, you can modify it!
open sources, open minds
This is the "main" script (you can convert in a function).
clc
clear all
close all
tau_s = 3e-9;
N0 = 1e24;
A =1e-12;
P0 = 1/(A*tau_s);
TSPAN = [0 10];
Y0 =[0 0];
[T,Y] = ODE45(@rate_equation,TSPAN,Y0);
subplot(2,1,1)
plot(T*tau_s ,Y(:,1)*N0)
title('Densità dei portatori nel livello laser superiore') % carriers density in high laser level
subplot(2,1,2)
plot(T*tau_s ,Y(:,2)*P0)
title('Densità dei fotoni nel mezzo attivo') % photons density in activer region
And this is the function.
function dy = rate_equation(t,y)
dy = zeros(2,1);
tau_s = 3e-9; % carriers lifetime
tau_p = 1e-12; % photons lifetime
A = 1e-12; % linear gain costant
N0 = 1e24; % trasparency carries density
V = 3.75e-14; % modal volume
gamma = 1e-5; % gain compression factor
q = 1.6e-19; % electron charge
I0 = N0*q*V/tau_s; % trasparency current
tau_norm = tau_s/tau_p;
eta = A*tau_p*N0; % efficiency
I = 2.5*I0; % pumping current ( try: from I0 to 3*I0 for example ...and see what happens!)
dy(1)= I/I0 -y(2)*(y(1) - 1) -y(1);
dy(2) = tau_norm*(y(2)*(eta*(y(1) - 1) -1) + gamma*eta*y(1));
% this is a very simple (dimensionless) and efficient version of the rate equations (note you
% can add another equation, dy(3)(not coupled), that gives you the phase(t) of your laser!
Sorry for my english!
I hope the world will live as one.
thanx to both of u my brothers. I am out of my stations right now... i will go back to my place tonight and i will try with your code. and offcourse I'll let u know. thank u once again for your concern. i am really greatful to u.
Some explanations:
The code is based on a rate equation dN/dt which shows only a linear dipendence from N (or from (N - N0)), where N0 is the trasparency density:
dN/dt = I/(qV) - A(N - N0) P - N/tau_s
where A is the linear gain of the laser medium, tau_s is the carrier lifetime(before spontaneous de-excitation). Here, I/(qV) represents the positive pumping rate, while A(N -N0)P and N/tau_s represent ,respectively, the negative absorption rate(which depends from incident photons density P) and stimulated emission rate(which depends from density and lifetime of the excited-level carriers).
Then, the second rate equation dP/dt will show similar terms:
dP/dt = A(N -N0)P -P/tau_p + gamma N/tau_s
where tau_p is the photon lifetime in the laser and gamma is the spontaneous emission coefficient(dimensionless).
In these equations:
= A
[A] = m^3/s
[V] = m^3
[tau_s] =[ tau_p] = s
[N] = [N0] = m^(-3)
[gamma] = 1
For Matlab implementation, it's a good idea to normalize the variables and, of course, the other parameters. The equations become:
dn/dT = I/I0 - p(n-1) - n
dp/dT = tau_norm * (p (eta(n -1) -1) + gamma*eta*n)
where
n = N/N0
T = t/tau_s
I0 = N0*q*V/tau_s
P0 = 1/(A*tau_s)
p = P/P0
tau_norm =tau_s/tau_p
eta = A*tau_p*N0
You can try the values of the parameters written in the code:
tau_s = 3 x 10^(-9)
tau_p = 1 x 10^(-12)
A = 1 x 10^(-12) [m^3/s]
N0 = 1 x 10^24 [m^(-3)]
V = 4 x 10^(-14) [m^3]
gamma = 1 x 10^(-5) []
I hope it's all clear. bye
thanx bro...thank u very much. i am greatful to u. you helped me a lot. i have one more question dear. can u give me a reference of this equation? I mean, from the paper u got these parameters. please let me know if u have any. that would be very kind of you. thanks again.
bro...I am waiting for your reply. can u please give me the link of the equation or the reference of this equation? please help me out. thank u
thanks to everyone : it's helpfull to share code. billboss, your code is just i was trying to obtain in matlab. I'm new with MATLAB programming and your code is an excellent starting point for the model i want to implement. thanks again
... just one thing : from your rate eqs. gamma is the spontaneous emission coefficient(dimensionless) as you say in youor second post and not the compression factor, as said in the first
the rate equation is
DN/Dt = I/qv - g0(N-N0)S/(1+epsilon*S) -N/Tow_s
i wanted to know why are we ignoring the term (1+epsilon*S)?
Thas far from truth. You should always adimensionalize your problem, as it will give you a general perspective on the system and (in nonlinear cases) important values to work with.
Imagine you want to model the behavior of a string of infinite length, tension [itex]N[/itex] and constant density [itex]\rho[/itex], with initial conditions [itex]u(x,0) = L_0 f(x)[/itex] and [itex]u_t(x,0) = v_0 g(x)[/itex], where [itex]f(x),\,g(x)[/itex] are dimensionless functions. Then the problem reads
[tex]\rho u_{tt}(x,t) - N u_{xx}(x,t) = 0,[/tex]
[tex]u(x,0) = L_0 f(x), \qquad u_t(x,0) = v_0 g(x).[/tex]
If you haven't stuidied this equation earlier, then there is no reason to believe that it will behave the same way for all parameters [itex]\rho,\,N,\,L_0,\,v_0[/itex]. Now, if you take the dimensionless variables
[tex]t = T t^*,\qquad x = X x^*, \qquad u(x,t) = L_0 u^*(x^*,t^*),[/tex]
then the problem transforms in
[tex]\frac{\rho}{T^2} u^*_{t^*t^*}(x^*,t^*) - \frac{N}{X^2} u^*_{x^*x^*}(x^*,t^*) = 0,[/tex]
[tex]u^*(x^*,0) = f(x), \qquad u^*_t^*(x^*,0) = \frac{T v_0}{L_0} g(x).[/tex]
Now, take
[tex]T = \frac{L_0}{v_0}, \hbox{ and } X = \frac{1}{c} \sqrt{\frac{NL_0^2}{\rho v_0^2}},[/tex]
where [itex]c[/itex] is a dimensionless parameter, then, by loosing the asterisks, the system becomes
[tex]u_{tt} - c^2 u_{xx} = 0, \qquad u(x,0) = f(x), \qquad u_t(x,0) = g(x).[/tex]
This is very important, as you can study any infinite string regardless of it's physicall parameters with the same equation. Furthemore, there is only one parameter to manipulate, instead of four. Once you've solved the wave equation, you only need to see how the solution varies with different c's, to know how the string will behave for different values of density, tension, etc.
I've portrayed a simple example here, but when dealing with nonlinear PDE's (or ODE's), the response of the system need not to be the same for different values of the dimensionless parameters, and it is crucial for the study of such systems, to analize the behavior of the PDE's for different values of the parameters. A classic example is the multiplicity of solutions. There are nonlinear PDE's depending on a parameter c that have two solutions for [itex]c \in (0,c^*)[/itex], one solution for [itex]c=c^*[/itex], and none for [itex]c \in (c^*,\infty)[/itex].
Wow. Thats cool AiRAVATA.
For analysis purposes I agree it is better to dimensionalize the equation. But when the programmer are only interested in the profile output, is it worthful to dimensionalize the equation first ?
Good morning!
Some of you, probably, hate me, because I gave my contribute, and then I flyed away from here...
But my university is a kind of nightmare, and I had a very bad time this year...
Anyway, I finished my work on laser DFB and I want to share it with us.
Sorry, the language of the document is italian...
Maybe, I'll translate it ... if there will be many questions!
Bye
At the beginning of the year Matlab was new to me. Please forgive me because my earlier posts were really an embarrassment. Didn't contribute to solving the problem. I just simply want to reply.
But today if I see a MATLAB code I can confidently interprete it. :biggrin:
Hi all, I've another problem. How L-I curve of laser diode can be obtained using this relations? I tried to define different amounts of I in script program but i could not use this in Function program. Please help me ...
Hi, Katla, try to read pages #28-31 of my little work (file "Paragrafi+Appendici.pdf"): I used only the relations which are there to obtain the L-I curve...
If you need a translation from italian, contact me here: info@billboss.homelinux.org
What you have to do in Matlab is essentially:
- create a working directory
- create the function "rate_equation" and the script (page 30) in the working directory
- run the script (eventually edit the values of parameters and/or the range of current values you want to sweep)
Dear billboss, thanks a lot for your attention and help :shy:
