What is the simplest and most cost-effective device for calculating power usage?
  • Thread starter Thread starter jpgnfx
    Device Power
The simplest and most cost-effective device for calculating power usage is a plug-in power meter, such as the Kill A Watt model available on Amazon for under $20. While basic calculations can be made using the formula P = VI, this method only applies accurately under unity power factor conditions. For more complex loads, such as motors or transformers, a power monitor that accounts for power factor is necessary. Devices from Analog Devices provide comprehensive monitoring capabilities but may require more investment and complexity than a basic plug-in meter.
  • Understanding of electrical power calculations, specifically P = VI.
  • Knowledge of power factor and its impact on power measurements.
  • Familiarity with plug-in power meters and their functionalities.
  • Basic electronics knowledge for those considering building a custom power meter.
  • Research plug-in power meters like the Kill A Watt for practical applications.
  • Explore power factor correction techniques for various appliances.
  • Investigate power monitoring solutions from Analog Devices for advanced applications.
  • Learn about DIY power meter projects and the components required for construction.
Homeowners, DIY enthusiasts, electrical engineers, and anyone interested in monitoring and optimizing power consumption in household appliances.
jpgnfx
Hi,
can anyone help with advice on what basic device can i use to calulate power usage?
the implementation I am looking at is follows
mains socket -- device -- appliance
its much like the product -> http://www.p3international.com/products/special/P4400/P4400-CE.html except i want to do away with the LCD and strip it to the bare minimum to basically reduce cost..
is there a basic device i can use? if I am not wrong, the device measures current and uses P = VI to convert to wattage.
thanks in advance
Not quite that simple. P=VI works only with unity power factor. That may or may not be a good approximation for you depending on the load. If the load is a motor or a transformer, the power factor will be lower. If it is something like an electric stove, power factor will be close to 1.
There are devices that do all the needed calculations for you. For example here
https://www.analog.com/en/products/monitor-control-protection/power-monitors.html
But building your own meter is a big project.
Can you just buy a meter that you plug the appliance into, such as: https://www.amazon.com/dp/B00009MDBU/?tag=pfamazon01-20
They cost less than $20.
10K
  • · Replies 24 ·
