Is my Free Body Diagram and Approach Correct for Finding Vertical Force on Tank?
The discussion focuses on verifying the approach to calculating the vertical force exerted on the bottom of a tank using a Free Body Diagram (FBD). The user confirms that the vertical force is determined by the difference between the buoyant force and the weight of the cylinder. It is established that the depth of the water does not affect the buoyant force calculation, as Archimedes' principle relies solely on the weight of the fluid displaced by the object.
  • Understanding of Free Body Diagrams (FBD)
  • Knowledge of Archimedes' principle
  • Basic concepts of buoyant force and weight
  • Familiarity with fluid mechanics
  • Study the application of Archimedes' principle in various fluid scenarios
  • Explore advanced Free Body Diagram techniques for complex systems
  • Learn about the relationship between pressure and buoyancy in fluid mechanics
  • Investigate the effects of different fluid densities on buoyant force calculations
Students in engineering or physics, educators teaching fluid mechanics, and professionals involved in tank design or buoyancy-related calculations.
Jason03
Im working on the problem below and trying to figure out if I have the right approach. I am checing to see if my free body diagram is correct. Also if finding the vertical force exerted on the bottom of the tank is just the differenence of the buoyant force and wieght of the cylinder as showin in my work. thanks
http://i674.photobucket.com/albums/vv106/jason03_2009/hw11.jpg
http://i674.photobucket.com/albums/vv106/jason03_2009/hw12.jpg
would I need to take into consideration the depth of the water?...or just the weight of the cylinder and the buoyant force?
Hi Jason,
Your calculations look fine. In calculating the buoyant force, the depth of the water isn't a consideration. Archimedes principal looks only at the weight of the fluid displaced by the solid object, not the pressure of the fluid.
11K
9K
