Dielectric constant for aliminium nitride
The dielectric constant of aluminum nitride at 0°C is 8.9 when measured at a frequency of 1 MHz. This value indicates the material's ability to concentrate electric flux and serves as a crucial parameter in capacitor design, where the capacitance is calculated using the formula C = εS/d, with ε being the product of the permittivity of free space (ε₀) and the dielectric constant (εᵣ). The dielectric constant is frequency-dependent, as higher frequencies can reduce the effective dielectric constant due to insufficient time for charge separation into dipoles.
  • Understanding of dielectric materials and their properties
  • Familiarity with the concept of permittivity and electric flux
  • Basic knowledge of capacitor design and capacitance calculations
  • Awareness of frequency effects on dielectric behavior
  • Research the impact of frequency on dielectric constants in materials
  • Explore capacitor design principles using different dielectric materials
  • Learn about the applications of aluminum nitride in electronics
  • Investigate the relationship between dielectric constant and energy storage capabilities
Electrical engineers, materials scientists, and anyone involved in the design and application of capacitors and dielectric materials in electronic devices.
sallyishyper
I know that a dielectric constant is the ratio of the permittivity of a substance to the permittivity of free space. It is an expression of the extent to which a material concentrates electric flux, and is the electrical equivalent of relative magnetic permeability. or in english terms: A dielectric material is a substance that is a poor conductor of electricity, but an efficient supporter of electrostatic field s. If the flow of current between opposite electric charge poles is kept to a minimum while the electrostatic lines of flux are not impeded or interrupted, an electrostatic field can store energy. but I am not entirly sure what this value means or represents. i don't think I've understood the concept properly, its entirely self taught:
constant for aliminium nitride is 0°C 8.9 at 1MHz
can somebody explain this please, i have no idea what it means
thankyou
constant for aluminium nitride is 0°C 8.9 at 1MHz
thankyou
It means, among other things, that if you construct a condenser with that material as a thin layer between two metal plates, the condenser's capacity (charge per unit voltage) is: [tex]\epsilon S/d[/tex] where [tex]\epsilon = \epsilon_0\epsilon_r[/tex] and [tex]\epsilon_r[/tex] is your 8.9. S is the area of the metal plates and d their distance (the material's thickness). It depends on frequency (if you want precision) because the polarization depends on it (for very high frequencies the charges don't have the time to separate into dipoles so the dielectric "constant" decreases).
Another way to consider it is to notice that the electric field is reduced by [tex]\epsilon_r[/tex] inside the material.
  • · Replies 16 ·
  • · Replies 27 ·
50K
21K
16K
