Can someone please explain this remark in Landau-Lifshitz's *Mechanics*?
  • Context: Graduate
  • Thread starter Thread starter AxiomOfChoice
    Explain Mechanics
The discussion clarifies the concept of "external field" as described in Landau-Lifshitz's *Mechanics*, specifically regarding momentum conservation in the presence of such fields. An external field refers to a field not influenced by the system's internal objects, such as a gravitational field affecting a particle's motion. The participants confirm that in a uniform field, like gravity in the z-direction, the x and y components of momentum remain conserved due to translational invariance. Additionally, the "field of an infinite homogeneous plane" is explained as a scalar potential where the potential does not vary in the x or y directions, resulting in zero force in those directions.
  • Understanding of Lagrangian mechanics
  • Familiarity with the concept of momentum conservation
  • Knowledge of vector and scalar fields
  • Basic principles of gravitational fields
  • Study the implications of translational invariance in Lagrangian mechanics
  • Explore the mathematical formulation of vector fields and their applications
  • Learn about gravitational potential and its role in classical mechanics
  • Investigate the properties of homogeneous fields in physics
Physicists, students of mechanics, and anyone interested in the principles of momentum conservation and field theory in classical physics.
AxiomOfChoice
Can someone please explain this remark in Landau-Lifshitz's *Mechanics* about fields?
On pg. 15, it says that "individual components [of momentum] may be conserved even in the presence of an external field."
What do they mean, exactly, by "external field?"
I know (or at least I think I know) that a given component of linear momentum is conserved if the system is translational invariant in that direction (that is, the Lagrangian does not depend explicitly on that coordinate). But how am I supposed to meld this with the idea of a field?
Landau-Lifgarbagez goes on to say that "...in a uniform field in the z-direction, the x and y components of momentum are conserved." I think I'd understand why this is if I had a clearer picture of what's meant by "field."
There is also an exercise at the end of this section that mentions the "field of an infinite homogeneous plane." What does that mean? As best I can tell, he is talking about a particle that moves in a plane subject to a potential energy that does not depend on the coordinates parallel to the plane. For example, if the plane in question is the x/y plane, the potential U satisfies
[tex] \frac{\partial U}{\partial x} = \frac{\partial U}{\partial y} = 0.[/tex]
Am I right or barking up the wrong tree? Thanks.
By external field, I presume they mean something like a gravitational field. A field is a term, which I (as a physicist) have always just thought of as the allocation of a value of some sort, i.e. number, vector, matrix, tensor, etc. to each point in a space. So we get a scalar field, vector field, matrix field and tensor field.
For example, the gravitation field can be given as a vector field where each vector represents the acceleration of an object of unit mass at that position. To find the actual acceleration, you must multiply the vector at that position by the reciprocal mass of the object.
Alternatively, it can be given by a scalar field, known as the gravitational potential. The force is given by the gradient of the vector field.
By external field, they mean a field whose origin is not related to the presence of other objects in the "system". So if we have two charged object, they will create an electric field between each other, but there will also usually be an externally applied gravitational field.
So if the Lagrangian of both the internally and externally applied field is independent of a particular co-ordinate, you may say that that component of momentum is conserved. I believe this is what the book is trying to say. When they mention the uniform field in the z-direction, I believe the authors were thinking about gravity and how it will not cause a change of momentum in the x and y directions.
The field of an infinite homogeneous plane means the value allocated to each point of an infinite homogeneous plane. In this case, U is taken to be the scalar potential (field). Thus the rate of change of the potential in the x-direction is equal to the rate of change of the potential in the y-direction which equals zero. So the force in all directions equals zero. This example doesn't sound very interesting to me though =)
  • · Replies 43 ·
  • · Replies 25 ·
