What is the inverse function of x^3 + 1 and how do you find its value at x = 4?
The inverse function of f(x) = x^3 + 1 is found by switching the x and y values and solving for y. The correct calculation for f^-1(4) yields approximately 1.44, as demonstrated by substituting 4 into the inverse function y = (x - 1)^(1/3). The confusion arose from incorrectly interpreting the inverse function as the reciprocal. The accurate approach confirms that f(1.44) is approximately equal to 4, validating the solution provided in the review book.
  • Understanding of inverse functions
  • Familiarity with polynomial equations
  • Basic algebraic manipulation skills
  • Knowledge of function notation
  • Study the properties of inverse functions in detail
  • Learn how to derive inverse functions for different types of equations
  • Practice solving polynomial equations and their inverses
  • Explore the concept of function composition to verify inverses
Students studying algebra, educators teaching inverse functions, and anyone looking to clarify the concept of function inverses in mathematics.
UrbanXrisis
I was just doing a problem in a review book and my answer doesn't match with what the books says.
It f(x)=x^3+1 and if f^-1 is the inverse function of f, what is f^-1(4)?
I got an answer of 0.02 but the book says it is 1.44.
All I did was sub in 4 into the equation, which I get 64, then set that under one...1/64 and get 0.02 as the inverse. How did the book get 1.44?
You're mistaking the inverse with the reciprocal.
The problem is asking for what value of x will satisfy f(x) = 4.
Clearly f(.002) does not equal 4, but 4(1.44) = 1.44^3 + 1 = 3.985984 ~ 4
cookiemonster
The notation is what really confuses people most of the time. The inverse of a function basically switches the x and y values. If you want to find the inverse for a function than all you would have to do is switch the values. In other words, replace all the x's with y's and vice versa. Than solve for y (assuming you originally had a y= equation) and you will have your inverse function. Than you can just plug your value in. In this case it would be:
y = x^3 + 1
For the inverse:
x = y^3 + 1
y = (x - 1) ^ (1/3)
so f^-1(4) = (4 - 1) ^ (1/3) = 3 ^ (1/3) ~ 1.44
  • · Replies 17 ·
  • · Replies 19 ·
