Various problems & questions - help,suggestion?
  • Thread starter Thread starter R A V E N
The discussion revolves around various physics problems, including kinematics, wave equations, and damped harmonic oscillators. Participants are exploring the underlying principles and notations used in these contexts.
  • Mixed
  • Participants are questioning the notation of derivatives in kinematics, specifically the meaning of the second derivative with respect to time. There is also a discussion about the representation of wave equations in different forms and the implications of phase shifts. Additionally, the nature of a damped harmonic oscillator is being examined, with participants analyzing statements regarding frequency and energy.
Some participants are providing clarifications on notation and concepts, while others are questioning assumptions and interpretations of the equations presented. There is an ongoing exploration of different representations of wave equations and their physical significance, as well as a critical examination of statements regarding damped oscillators.
Participants are navigating language barriers, with one expressing concern about clarity due to English not being their first language. The discussion includes references to different educational resources and potential variations in terminology between regions.
R A V E N
Code:
Question 1.
From kinematics we have [tex]a=\frac{\mathrm{d}^2s}{\mathrm{d}t^2}[/tex] which means,as I understood it:to get the acceleration,we first derive distance with respect to time,then again derive the result of that operation with respect to time.
If so,wouldn`t be more appropriate to write [tex]a=\frac{\mathrm{d}^2s}{\mathrm{d}t}[/tex] - I mean,what [tex]2[/tex] represents in [tex]\mathrm{d}t^2[/tex]?
d2x/dt2 is the correct notation for the second derivative.
Think of it more as Δ(Δx/Δt)/Δt, where the limit is applied as Δ tends toward 0.
Code:
Question 2:
The second question is about equation which describes a wave in air which originates from vibrating string attached to both of its ends and strained by some force.I know that people in United States and UK represent this equation in different form,so I`ll describe every parameter.The equation is:
[tex]y=A\sin(\omega t-kx)[/tex].
However,in one book it is given like:
[tex]y=A\cos(\omega t-kx)[/tex].
Why this second form is used and where it comes from?If I understood it correctly,it is the first equation where phase of the wave is shifted by [tex]+\frac{\pi}{2}[/tex],so the origin point of the Cartesian coordinate system used to analyze wave is moved for the corresponding length to the right,but for what purpose?
______________________________________________________________________________
[tex]y[/tex] - displacement of the particle of air caused by the wave in the moment of [tex]t[/tex] and at the distance of [tex]x[/tex] from the origin point of the Cartesian coordinate system used to analyze the wave
[tex]A[/tex] - amplitude of the wave
[tex]\omega=\frac{2\pi}{T}[/tex] and [tex]k=\frac{2\pi}{\lambda}[/tex] where [tex]T[/tex] is the period of the wave and [tex]\lambda[/tex] is the wavelenght of the wave.
Code:
Question 3:
We have a damped harmonic mechanical oscillator - a moving body on the spring.If force of damping is proportional to the speed of that body then:
a)none of the statements below is true
- CORRECT
b)frequency decreases with time - INCORRECT,SINCE FREQUENCY IS NOT FUNCTION OF TIME:
[tex]\omega=\sqrt{\omega_0^2-\frac{c^2}{4m^2}}[/tex]
c)displacement of body is sinusoidal function of time - INCORRECT,INSTEAD IT IS A SINUSOIDAL FUNCTION OF ANGULAR DISPLACEMENT
d)velocity of body is sinusoidal function of time - INCORRECT,INSTEAD IT IS A SINUSOIDAL FUNCTION OF ANGULAR DISPLACEMENT
e)mechanical energy is constant - INCORRECT,MECHANICAL ENERGY APPROACHES TO ZERO AS TIME PASSES
Have I answered and explained all this right?Actually,this is a trick question,since force of damping is ALWAYS quantitatively proportional to the speed of damping [tex]F=cv[/tex].
Have I wrote something non-understandable since English is not my first language?
R A V E N said:
Code:
Question 2:
The two questions described two different scenarios.
For example, the first could describe a pendulum that starts from its equilibrium position. The second equation could represent a pendulum that starts from it's maximal displacement: imagine someone pulling a pendulum to the side and then releasing it.
Does that make sense?
  • · Replies 70 ·
