Understanding Hadley and Whitin's Reorder Point Formula for Logistics
  • Context: Graduate
  • Thread starter Thread starter jacophile
    Formula Point
This discussion centers on understanding Hadley and Whitin's Reorder Point Formula in inventory management, specifically the variance of the reorder point process. The formula for the reorder point R is defined as R = E(X) + Z StdDev(X), where E(X) is the expected demand during lead time, Z is the inverse CDF of the desired service level, and StdDev(X) is the standard deviation of demand. The relationship between demand and lead time is established through the equations E(X) = E(d)E(LT) and Var(X) = Var(d)(E(LT))^2 + Var(LT)(E(d))^2 + Var(d)Var(LT). The discussion concludes with the derivation of the reorder point formula R = E(d)E(LT) + Z √(E(LT)Var(d) + E(d)^2Var(LT)).
  • Understanding of random variables (RVs) and their properties
  • Familiarity with moment generating functions (MGFs)
  • Knowledge of inventory management concepts, particularly reorder points
  • Basic statistics, including mean and variance calculations
  • Study the application of moment generating functions in probability theory
  • Learn about the characteristics of independent random variables in inventory systems
  • Explore advanced inventory management techniques, including safety stock calculations
  • Investigate the implications of service levels on reorder point strategies
Logistics professionals, inventory managers, data analysts, and anyone involved in optimizing inventory systems and understanding demand variability.
jacophile
Hi, I am trying (in vain) to understand a common result in logistics due to Hadley and Whitin.
It is about the variance of the reorder point process in an inventory management system.
It is assumed that the demand X during lead time has a normal distribution with mean E(X) and variance Var(X). Then, the re-order point is set equal to:
Where
X is a RV representing the demand for one lead time
R is the re-order point i.e. the inventory level at which a replenishment order should be placed
The service level is the probability that there will be sufficient stock to meet demand
This makes sense to me because it transposes to
[tex]SL = F(\frac {R - x} {StdDev(X)})[/tex]
so R is the mean of this process and Z.StdDev(X) is the safety stock
The lead time is the time it takes for a replenishment order to arrive and is also a RV independent of the demand
So,
X = d x LT
Where
d is the demand per unit time process (a RV) and
LT is a RV representing the lead time and
d an LT are independent
So my understanding is that
[tex]E(X) = E(d)E(LT)[/tex]
[tex]Var(X) = Var(d)(E(LT))^2 + Var(LT)(E(d))^2 + Var(d) Var(LT)[/tex]
The result that is normally given is (due to Hadley and Whitin 1963)
[tex]R = E(d)E(LT) + Z \sqrt {E(LT)Var(d) + E(d)^2Var(LT)}[/tex]
But I can not see why.
can anyone help me out?
Hmm, I guess my post was too confusing. Any way I think I worked it out..
Just to re-state the problem (hopefully more clearly),
What is the distribution of the sales demand for a stock item during the replenishment lead time (DLT), given that the daily demand D and the lead time N are independent random variables and the sequence of daily demand D, during the lead time period are iid.
The replenishment lead time N is the number of days between placing an order for more stock and actualy taking delivery of it. The general idea is to have enough stock buffer to cover the variance in D and N.
I was trying to imagine how to multiply D and N but I realized that the demand during lead time (DLT) is actually a sum of a random number of random variables:
[tex]DLT\;=\;\sum_{i=1}^{N}D_i[/tex]
Then I discovered the characteristic function and moment generating functions (I had no idea about these things so it was a massive eye-opener...) by which I understand I can proceed as follows:
[tex]Define \;R \equiv e^{DLT \; t}[/tex]
[tex]E(R \mid N=n)\;=\;E(e^{DLT \; t} \mid N=n) \; = \; E(e^{(D_1+D_2+...+D_n) \;t}) \; = \; (M_D(t))^n \; \;[/tex]
where [tex]M_D(t)[/tex] is the moment generating function for D
Now let the condition be a rv so that the expectation above also becomes a rv defined as
[tex]E(R \mid N) \;= \; (M_D(t))^N[/tex]
so the mean of this rv is
[tex]E(E(R \mid N)) \; = \; E(R) \; = \; E((M_D(t))^N)[/tex]
Also,
[tex]E(R) \; = \; E(e^{DLT \; t}) \; = \; M_{DLT}(t)[/tex]
by the definition of the mgf.
This leads to
[tex]M_{DLT}(t)\; = \; E((M_D(t))^N).[/tex]
I had no trouble convincing myself that the zero'th, first and second derivatives of the mgf are the zero'th, first and second moments about zero, so now I can go ahead and differentiate
[tex]M_{DLT}'(t)\; = \; E(N M_D^{N-1}(t) M'_D(t))[/tex]
[tex]M_{DLT}''(t)\; = \; E(N(N-1) M_D^{N-2}(t) M'_D(t) M'_D(t)+N M_D^{N-1}(t)M''_D(t))[/tex]
It is then straight forward to show that
[tex]E(DLT) \;=\; M_{DLT}'(0)\; = \; E(D)E(N)[/tex]
and that
[tex]Var(DLT) \;=\; E(N^2)Var(D)+E(N)Var(D)[/tex]
which is exactly the result I was confused about.
  • · Replies 0 ·
  • · Replies 0 ·
