Magnetic field of a finite-length wire
The discussion revolves around calculating the magnetic field at a distance from a finite-length wire carrying a current. Participants explore the applicability of Ampere's Law in this context, particularly questioning the assumptions related to symmetry and the behavior of the magnetic field around the wire.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants discuss the reasoning behind applying Ampere's Law to a circular path around the wire and question why this leads to incorrect results. There are attempts to relate the magnetic field of a finite wire to that of an infinite wire, and some participants express curiosity about the differences in magnetic field calculations for wires of varying lengths.
The discussion is ongoing, with participants sharing insights and formulas related to the magnetic field of finite and infinite wires. Some guidance has been offered regarding the limitations of Ampere's Law in this scenario, particularly concerning the symmetry of the magnetic field.
Participants are navigating the complexities of applying theoretical laws to practical scenarios, particularly focusing on the implications of wire length and the resulting magnetic field characteristics. There is an acknowledgment of the need for high symmetry in using Ampere's Law effectively.
Chen
Let's say I want to calculate the magnetic field at a distance d from the center of a wire of finite length L, carrying a current I. Why would it be wrong to apply Ampere's law to a circular path of radius d centered on the wire, and say that the integral of B.dl is simply B times 2pi*d? (obviously it gives the wrong answer...)
Is the magnetic field not constant along this circular path? I would say so - the problem obviously has cylindrical symmetry.
Is it not parallel to the path at all points? I would think so - from Biot-Savart's law applied to every small element of the wire.
So where is the mistake in this logic?
Thanks,
That makes a lot of sense, Chen. Do you happen to know what B is around a "short" current carrying wire? It would be interesting to see how it is different from the B for an infinitely long one. I would expect a slightly smaller answer due to the "missing" length on either side.
Looks to me like the finite length L in the Biot-Savard Law gives you a factor of
L/sqrt(L^2 + r^2). Anyhow it goes to 1 as L goes to infinity.
Interesting, but it does not answer your question of why Ampere's Law cannot be applied to the finite length! If you find the answer, I hope you will let me know.
There is a formula here:
http://www.ac.wwu.edu/~vawter/PhysicsNet/Topics/MagneticField/MFStraitWire.html
If we limit our discussion only to the center of the wire, theta=phi and you obtain the result of an infinite wire, times cos(theta). And I am not at all sure where in Ampere's law this factor comes from. There is probably some fine print that I'm missing here.
dB = u*i/(4*pi)*sin(A)*dx/r^2 where x runs from -L/2 to L/2, sin(A) = R/r
and r = sqrt(x^2 + R^2)
Here R is the distance from the wire center to the point we are computing B for.
B = u*i/(4*pi)*integral R*dx/(x^2 + R^2)^1.5
B = u*i/(4*pi*R)*[x/sqrt(x^2 + R^2)] evaluated between -L/2 and L/2.
B = u*i/(2*pi*R)*L/sqrt(L^2 + R^2)
This is from the standard derivation for the infinite wire, with only the integral limit being changed to -L/2 to L/2.
Thanks. But I know how to calculate this with Biot-Savart's law. I want to know where the application of Ampere's law to this problem fails.
Ampere's Law is only useful in calculating B for situations with very high symmetry. When calculating B of an infinite wire using Ampere's law we choose our path to be a circle around the wire so that B will always be tangent to our path. If the length of the wire isn't large compared to the distance r where we calculate B, this assumption is no longer valid (the B field is no longer symmetric in this way).
In short your assumption that a finite wire's B field has cylindrical symmetry is not correct--the effects of the ends make the field lines shaped oddly and not in a way Ampere's Law can work for us.
