How to Calculate the Kinetic Energy of a Moving Spring?
  • Thread starter Thread starter makeAwish
    Mass Spring
The discussion focuses on calculating the kinetic energy of a moving spring, specifically one with mass M, equilibrium length L0, and spring constant k. The kinetic energy is derived by considering the spring's mass distribution and the varying speed of its points along its length. The key equations include v = (qL^2)/2 for speed and m = (M^2)/(2 λ) for mass, where λ represents linear mass density. The solution involves integrating the energy of infinitesimal pieces of the spring to find the total kinetic energy, which is not simply 0.5Mv^2 due to the non-uniform speed distribution.
  • Understanding of classical mechanics, specifically kinetic energy concepts
  • Familiarity with calculus, particularly integration techniques
  • Knowledge of spring mechanics, including Hooke's Law and spring constants
  • Concept of linear mass density (λ) and its application in physics
  • Study the derivation of kinetic energy for non-uniformly moving objects
  • Learn about the application of integration in physics problems
  • Explore advanced topics in spring dynamics and energy storage
  • Investigate the relationship between mass distribution and motion in elastic materials
Students and educators in physics, particularly those focusing on mechanics and energy calculations, as well as engineers working with spring systems and dynamic materials.
makeAwish
We usually ignore the kinetic energy of the moving coils of a spring, but let's try to get a reasonable approximation to this. Consider a spring of mass M, equilibrium length L0, and spring constant k. The work done to stretch or compress the spring by a distance L is 0.5kx^2, where x = L – L0.
(a) Consider a spring, as described above that has one end fixed and the other end moving with speed v. Assume that the speed of points along the length of the spring varies linearly with distance l from the fixed end. Assume also that the mass M of the spring is distributed uniformly along the length of the spring. Calculate the kinetic energy of the spring in terms of M and v.
(Hint: Divide the spring into pieces of length dl; find the speed of each piece in terms of l, v, and L; find the mass of each piece in terms of dl, M, and L; and integrate from 0 to L. The result is not 0.5Mv^2, since not all of the spring moves with the same speed.)
The attempt at a solution
v = (qL^2)/2 where q is the constant proportionality of v and l
m = (M^2)/(2 landa) where landa is the linear mass density
I'm not sure if my current workings are correct. And how to get rid of these constants?
this in an integral question
you need to show you got your equations, try writing down an equation for the energy of an infinetesimal piece of the spring ie. dE in terms of v(x) and dm, then think how dm is related to dx
  • · Replies 27 ·
