Assembly language: Why wouldnt my code work the way i want it to?
The discussion revolves around a user's assembly language code intended to convert lowercase strings to uppercase and prompt the user for continuation. Participants explore issues related to conditional branching, code structure, and the inclusion of external files in the assembly code.
  • Homework-related
  • One participant describes their assembly code and expresses frustration that the program stops regardless of user input.
  • Another participant identifies a problematic line of code where a comparison is made followed by an unconditional exit, suggesting the need for a conditional branch.
  • A participant requests clarification on how to implement a conditional branch in assembly language.
  • Another participant explains the use of various jump instructions (e.g., jz, je, jne) and provides an example of how to structure conditional branches.
  • A participant modifies their code to handle invalid user input by prompting the user repeatedly until valid input is received.
  • One participant suggests including carriage return and line feed characters in print statements to ensure proper formatting in output.
  • A participant expresses confusion about how to include external files in their code and seeks advice on replacing the include statement.
Participants generally agree on the need for conditional branching in assembly language, but there are differing opinions on how to implement certain aspects of the code, such as handling user input and including external files. The discussion remains unresolved regarding the best practices for including external libraries.
Participants mention specific assembly language instructions and conventions, but there are unresolved questions about the implications of using certain includes and how they affect program behavior.
kloong
this is my code to convert lower case strings to upper case.
i want to ask the user whether to continue or not. but no matter what i type, the prog keeps stoping. try to copy paste this code to ur emulator and u'll know what I am saying.
also, how should i replace the include 'emu8086.inc' with??
.MODEL SMALL
.STACK 100H
.DATA
MSG1 DB 0DH,0AH,"ENTER A LOWER CASE LETTER: $"
MSG2 DB 0DH,0AH, "IN UPPER CASE IT IS:"
CHAR DB ?, "$"
.CODE
MAIN PROC
MOV AX, @DATA
MOV DS, AX
label3:
LEA DX, MSG1
MOV AH, 9
INT 21H
MOV AH, 1
INT 21H
CMP AL, 'z'
JG label1
CMP AL, 'a'
JL label2
SUB AL, 20H
MOV CHAR, AL
LEA DX, MSG2
MOV AH,9
INT 21H
JMP label4
label1:
PRINT ' Please enter a lower case alphabet for conversion!'
jmp label3
label2:
jmp label3
label4:
PRINT ' Do you want to continue?<y/n>'
MOV AH, 1
INT 21H
CMP AL, 'n'
int 20h
CMP AL, 'y'
jmp label3
exit:
MAIN ENDP
END MAIN
Technology news on Phys.org
The problem is here:
CMP AL, 'n'
int 20h
You do a compare, but then exit (int 20h) no matter what. You need a conditional branch after a compare.
I don't know what emu8086.inc does, are you running on a non-intel cpu?
If you're using MASM, (Microsoft's assembler), it defaults to 8086 unless you specify a cpu, such as .186 or .686.
i see. so how i should i do a conditional branch? can you show it to me?and i am using the 8086 emulator. if i take that out, there will be a warning message that says my parameter is wrong. i copied that line from the example given. er, how should i fix that?
Well, CMP does a logical subtraction between source and destination, so you should use:
jz: jump if zero
je: jump if equal
jne: jump if not equal
jnz: jump if not zero
jg: jump if greater than
jge: jump if greater than or equal to
jl: jump if less than
jle: jump if less than or equal to
I would recommend using these, and not the ones for unsigned arithmetic, since the logical subtraction is involved (suggestion).
For example:
cmp al, 'n'
je equalToNBranch
jmp notEqualToNBranch
equalToNBranch: ; code for the case al == 'n'
jmp done;
notEqualToNBranch: ; code for the case al =/= 'n'
jmp done;
done: ; further code...
Not the most efficient usage, but hopefully clear enough to give you the idea.
thanks, it works and i also mod-ed it to work so that when the user enter something other than y/n, it will keep asking the user to enter y/n again. but how do i make them go to a new line everytime?
label4:
MOV AH, 1
INT 21H
CMP AL, 'n'
JE label6
JNE label7
label7:
CMP AL, 'y'
JE label3
JNE label4
label6:
int 20h
You left out the 0dh and 0ah in the print statements. Try 0dh, 0ah, ' ...' to see if that's allowed.
i know 0dh and 0ah. but that can't work.
but the more important question i have now is, how do i 'declare' or 'pass' the parameter?
in my code, i used something like: include emu8086:
which, i copied from the example. if i don't do that, the "PRINT" wouldn't work. i know it's bad programming but i didnt know what to do. so what should i do to replace that line (include emu8086)?
anyway, this is my code:
.MODEL SMALL
.STACK 100H
.DATA
CHAR DB ?, "$"
.CODE
MAIN PROC
MOV AX, @DATA
MOV DS, AX
label3:
LEA DX, MSG1MOV AH, 9
INT 21H
MOV AH, 1
INT 21H
CMP AL, 'z'
JG label1
CMP AL, 'a'
JL label2
SUB AL, 20H
MOV CHAR, AL
LEA DX, MSG2
MOV AH,9
INT 21H
JMP label4label1:
jmp label3
label2:
jmp label3
label4:
MOV AH, 1
INT 21H
CMP AL, 'n'
JE label6
JNE label7
label7:
CMP AL, 'y'
JE label3
JNE label4
label6:
int 20h
exit:
MAIN ENDP
END MAIN
sorry again. it's all good now. thank you, Jeff and csprof2000! have a nice day! =)
  • · Replies 20 ·
11K
