| Thread Closed |
Non-uniform electric field and a dipole |
Share Thread | Thread Tools |
| Feb21-09, 01:32 PM | #1 |
a dipole, [tex] \vec p [/tex], is in a non uniform field, [tex] \vec E = (E) \vec i [/tex] where [tex] \vec E [/tex] points along the x axis. What is the net force on the dipole if [tex] \vec E [/tex] depends only on x? 2. Relevant equations [tex]| \vec{p} \times \vec{E}| = | \vec p | | \vec E | sin \theta [/tex] 3. The attempt at a solution i think if the charges are separated by dx, [tex] \vec p = (Q) (dx) (\vec i) [/tex] then, i get a bit confused.... what thinking step shall I take next??? |
| Feb21-09, 08:54 PM | #3 |
Recognitions:
| Feb21-09, 09:02 PM | #4 |
Non-uniform electric field and a dipole[tex] Q \vec E = \vec F [/tex] pure dipole. |
| Feb21-09, 09:05 PM | #5 |
Recognitions:
| Feb21-09, 09:14 PM | #6 |
oh come on, you're treating me like some scrub. I know the equation... positive force plus negative force in which the Electric field from the dipole decreases by 1/r cubed for far distances.... I've done a lot of thinking on this problem.. GeeZ! [tex] \vec F = \vec F_+ + \vec F_- = (Q \vec E_+ - Q \vec E_- ) \cdot \vec i [/tex] what thinking step shall I take next??? |
| Feb21-09, 09:27 PM | #7 |
Recognitions:
The general equation for the force on a dipole (pure or physical) is derived in almost every introductory level E-M textbook I've come across...is it truly not derived in your textbook?....Which textbook does your course use and what level course is this for? |
| Feb21-09, 09:35 PM | #8 |
| Feb21-09, 09:43 PM | #9 |
Recognitions:
If so, then you can continue on from here: |
| Feb22-09, 02:50 AM | #10 |
if the dipole vector [tex] \vec p [/tex] is parallel to the x axis and points to the + x direction, then
[tex] \vec E = (E) \vec x [/tex] [tex] \vec F_- = - ( \vec E ) (Q) [/tex] [tex] \vec F_+ = ( \vec E ) (Q) [/tex] [tex] \vec F_- = - (E) \vec x (Q) [/tex] [tex] \vec F_+ = (E) \vec x (Q) = (E) (x + dx) (Q) [/tex] i'm stuck... |
| Feb22-09, 03:33 AM | #11 |
Recognitions:
What a jumbled mess!....please use \hat{} to represent unit vectors and \vec{} for normal vectors; it will make things less confusing....and be careful with your brackets! ([itex](E) \vec x[/itex] means E times the vector x; while [itex]E(x)\hat{i}[/itex] means E as a function of x, directed along the x-axis--which is what I'm sure you meant to write)I'm sorry if this sounds rude, but I think you should consider getting a tutor. I think some face to face assistance could really benefit you. At this point, you seem to have made at least 3 assumptions without justification; (1) the first is that the dipole consists of two point charges [itex]\pm Q[/itex] separated by a distance [itex]dx[/itex], (2) the second is that the dipole points in the x-direction, (3) and the third is that the negative charge is located at [itex]\vec{r}=x\hat{i}[/itex] From your original problem statement, I see absolutely no reason to make these assumptions: Again I ask what level course this is for, and what the course textbook is? (If I have a copy of the same text, I can point to any helpful sections) |
| Feb22-09, 04:01 AM | #12 |
I'm offended by your remark. It seems like you haven't put any thought into this problem, or maybe you don't understand...and you say I made unjustified claims??? |
| Feb22-09, 04:12 AM | #13 |
Recognitions:
Instead, I would assume that p points in any direction (that way you can derive what the force on the dipole is in the general case, instead of just when it is aligned with the field). I would also assume that the question refers to a pure dipole, and that E=E(x)i. In such a case, it is easy to show that [tex]\vec{F}(\vec{r})=(\vec{p}\cdot\hat{i})E'(x)\hat{i}[/tex] where [itex]\vec{r}[/itex] is the location of the dipole) |
| Feb22-09, 07:39 AM | #14 |
Recognitions:
At the risk of entering such a contentious thread, I will inform you that the force on a dipole [tex]{\vec p}[/tex] in an electric field [tex]{\vec E}[/tex] is
[tex]{\vec F}=\nabla({\vec p\cdot{\vec E}}).[/tex] |
| Feb22-09, 11:59 AM | #15 |
Recognitions:
[tex]\vec{F}=(\vec{p}\cdot\vec{\nabla})\vec{E}[/tex] This is the formula that I recommended he look up in his textbook, as it is derived in almost every introductory level EM text I've come across. |
| Feb22-09, 07:40 PM | #16 |
thanks gab,
My introductory physics book does not have this derivation. Instead, it asks me to figure out the derivation. Would you recommend a better physics textbook that has this derivation? REZNICK? GIANCOLI? IDA? SERWAY?? KNIGHT? WHICH ONE??? |
| Feb22-09, 07:54 PM | #17 |
Recognitions:
However, seeing as it isn't in your text, you must be expected to derive the expression in post #13 by means of a Taylor series expansion and the limiting process I described at the beginning of the post. Try expanding the E(x+dx) around the point x assuming dx<<x and then substitute that into your expression for the force. (since you don't know what E(x) is, there is no way to dtermine what E'(x), E''(x) etc. are so just write them as E'(x) etc.) |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Non-uniform electric field and a dipole
| period of an electric dipole rotating in an external electric field | Introductory Physics Homework | 2 | ||
| Ferromagnetic dipole in a uniform magnetic field | Introductory Physics Homework | 10 | ||
| Electric dipole charges/Electric Field | Introductory Physics Homework | 3 | ||
| Electric field of a dipole | Advanced Physics Homework | 0 | ||
| Electric field due to dipole | Introductory Physics Homework | 2 | ||
