Vector-Valued Function Question
  • Thread starter Thread starter faslickit
    Function
The discussion revolves around vector-valued functions, specifically finding the y-intercept of a line in 2-space and determining the intersection points of a line with a given plane. Participants are exploring the mathematical reasoning involved in these vector equations and their geometric interpretations.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss methods to find the y-intercept by setting the x-coordinate to zero and solving for the corresponding y-value. There are also attempts to express the intersection of the line with the plane through vector equations and coordinate comparisons.
Some participants have provided guidance on how to approach the problems, suggesting methods to find the y-intercept and to set up equations for the intersection. There is a recognition of the need for a more systematic approach rather than relying on guess and check, though no consensus on a definitive method has been reached.
Participants mention the importance of understanding the position vector in relation to the equations provided. There is also a note of uncertainty regarding the completeness of their solutions and the need for a proper method to finalize their answers.
faslickit
(a) Find the y-intercept of the line in 2-space that is represented by the vector equation r = (3+2t)i+5tj
(b) Find the coordinates of the points where the line r = ti + (1+2t)j - 3tk intersects the plane 3x-y-z=2
For a, I'm pretty sure it's (0,-7.5), just took (3,0) and went in the direction v=2i+5j to the y-intercept.
For b, I listed the point (0,1,0) from the coordinates of r and the vector v=i+2j-3k. After combining them with guess and check, I came up with the answer of (3/4, 10/4, -9/4).
I'm pretty sure I have the right answers, but I technically ended both with guess and check. What is the proper way to finish both problems?
For part (a) think about it this way- you are looking to find the y-intercept, so looking in terms of a 2-D plane, if you are looking at a y-intercept what is your x-value? So take that value and set it equal to X and then solve for the time(t) when you are at that point. Then plug that t into your equation.
for (b)- try kind of thinking along the same lines of the other question in terms of what you can imply from the question.
a) To y-intercept, so set 3 + 2t = 0 and solve for t. Then use that value to get the y value (5t) at the y-intercept.
b) This one is a bit more involved. The vector equation of the line is r(t) = (t, 1 + 2t, -3t). The equation of the plane is 3x - y - z = 2, and this can be put in the form of a vector equation this way:
3x = y + z + 2
or
x = 1/3 * y + 1/3 * z + 2/3
y = y
z = z
The last two equations are trivially true, and are thrown into give us a vector equation, namely
(x, y, z) = y*(1/3, 1, 0) + z*(1/3, 0, 1) + (2/3, 0, 0).
At any point of intersection, the point (x, y, z) on the line must also be on the plane, so the x-coordinates have to be equal, as do the y-coordinates and the z-coordinates.
This means that
(t, 1 + 2t, -3t) = y*(1/3, 1, 0) + z*(1/3, 0, 1) + (2/3, 0, 0), or
t = 1/3 * y + 1/3 * z + 2/3
1 + 2t = y
-3t = z
Solving the last two equation for y and z gives us y = 2/3*t + 1/3 and z = -t.
Substituting these values into the first equation just above yields t = 3/4 at the point of intersection, which gives us the point (3/4, 5/2, -9/4), which is what you got.
For both of these you need to know that the position vector, r, of the point (x, y, z) is always xi+ yj+ zk. I hope you knew that but didn't think to use it.
The x intercept is when x= 3+ 2t= 0. Solve for t and put that into y= 5t.
x= t, y= 1+ 2t, z= -3t. Put those into the equation 3x- y- z= 2 to get an equation for t.
  • · Replies 20 ·
