Thread Closed
rotational coil induction
Share Thread Thread Tools
Feb22-09, 08:44 PM   #1
1.A circular coil, with radius of 10 cm, and 25 turns, rotates in a constant magnetic field of
strength 2.4 T, with the axis of rotation perpendicular to the direction of the magnetic
field.
A. If the coil rotates at a frequency of 50 Hz, what is the induced peak voltage?
B. Sketch the time-dependence of the induced voltage.
C. If the magnetic field that the coil is in points down the page, which direction does the coil rotate? Answer for both cases: (1) q traveling from left to right and (2) q traveling from right to left in the coil.
2. Relevant equations
V = -N * [ dΦ / dT ]
Φ = B * A * cosθ
V = -N * B * A * ω*sinθ
ω = 2π*f
3. The attempt at a solution
A. A = π*.1^2
.031416 m^2
ω = 2π*50
314.159 rad/s
peak voltage would occur when the coil is perpendicular to the magnetic field correct? So would I put π/2 in for sin(x) and get the following?
V = 25 * 2.4 * .031416 * 314.159*sin(π/2)
1.88496 * 314.159
592.177 V
B. If A is correct, then would the time-dependence of induced emf look like a sin wave?
C. I take it I'm supposed to use the right-hand-rule and Lenz's Law for this question, but I'm slightly confused as to how to go about doing so
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Feb23-09, 06:29 PM   #2
bump, I believe A and B are correct from what I understand, but I'm still having trouble with C.
Apr1-09, 12:19 AM   #3
I need help with this question too.
Apr14-09, 08:18 PM   #4
Yeah, I don't understand how to use the 50Hz to determine the peak voltage. I really hate this class! None of this was taught in the lesson or explained at any point. An explanation of the equations would be helpful. Please, anyone?
Thread Closed
Thread Tools
Similar Threads for: rotational coil induction
Thread Forum Replies
Induction in Toroidal Coil Classical Physics 7
how to not short circuiting an induction heating coil General Engineering 11
benefits of induction coil over an alternator? Electrical Engineering 0
Magnetic Flux (Induction - Magnet through a coil) Introductory Physics Homework 1
Induction Coil Sensors Electrical Engineering 1
